Re: PR based LED modules - other than EveLed?
Firstly, we need to define your expectations, and perhaps your price range. Also we need to set down some basics. All white LED dies to date require about 3.4V to 3.6V input as a minimum. (That's why the 5W needs 7V in because of the 2+2 parallel-serial setup).
With a 2AA flashlight you can't expect to run any white LEDs at full strength without some sort of booster circuit. You could run red and yellow/amber LEDs from 2V up, but not white.
Next, how bright do you want it? A single 5mm LED would be about as bright as a Mag Solitaire. Approx 17 of these would equate to 1 1W Luxeon Star driven at spec. And since the head of the flashlight you are putting the LEDs into is plastic, I don't think you'll want to drive the LS too hard because it would be difficult to get rid of the heat.
After all of that, you should realise that for white LEDs, you really need to be looking at a boosted solution. There is the NitePearl bulb that made its debut quite a while ago, as Illuminated mentioned. It is boosted so that it will drive the LED at spec, but being only 1 LED, it would not be very bright.
The EverLED has the 1W LS and electronics to prevent overheating (as well as being able to handle a huge range of Vin). It would probably be your best choice.
The Epion is an unboosted option. This is possible because the 1W LS had quite a huge variation in Vf. So the manufacturers just binned them according to their Vf and those with the lowest Vf were sold as suitable for 3V applications. When used with alkalines, these bulbs get dim very quickly as the Vbatt rapidly drops below Vf.
Other possible options, but would require modding skills, would be to put in a module from the Sandwich Shoppe, or a modified SatCure circuit, or something similar in to the head along with enough 5mm LEDs or a single LS to make it bright enough.
