Hi all, first post, but I’ve been researching this forum for a few weeks.
I have a problem with my first high-power LED build that I hope someone here can help me with.
I am building a headlight for my electric bicycle and want to drive it directly from the main battery which is a nominal 26VDC, 11.5Ah LiFePo4 pack. The battery voltage ranges from 29.1VDC straight off the charger to about 21VDC at the BMS cutoff.
Based on research here and on the Mountain Bike forum, I decided to go with a single MC-E LED, series-wired on a round base and a Recom RCD-24-0.70 (wired) driver (both bought from Cutter). I chose the Recom driver as it has an absolute max input voltage rating of 40V and a recommended max input voltage of 36VDC which is well over my max battery voltage of 29.1V.
I intend to mount the LED into a DX E27 housing, but that is the next step.
As a prototype, I mounted the LED on a decent sized heatsink designed for a TO-3 power transistor, with a couple of screws clamping down opposite sides of the pill. I used heatsink compound to ensure good thermal conduction.
I wired up the LED to the Recom driver and also wired up the analog dimming circuit shown in the Recom datasheet using a 4k7 resistor and 1k pot to drive the analog Dim connection. The circuit is shown operating from 24VDC, but I calculated the voltage from the resistive divider at 29V and the max voltage to the Analog Dim input was 5V which is well within the 15V max rating for that pin.
I connected the driver to a 15VDC bench power supply and everything worked fine. I was able to slightly dim the LED with the Pot, but as the 15V input through the resistive divider only gave about 2V max at the Dim wire, this would only dim to about 50%. None of the components got hot and the LED output was nice and bright.
I then connected the Recom driver to the 29VDC battery and switched on. There was a brief low-level flash from the LED and then nothing. I reconnected the driver to the 15VDC power supply, but nothing happened. After a few checks, I discovered that BOTH the Recom Driver and the MC-E LED were dead! :mecry:
Can anyone explain what I did wrong as I don’t understand why the circuit didn’t work at 29V as I don’t believe I exceeded any of the absolute maximum ratings for the Recon driver. I understood that the constant current driver would automatically adjust itself to deliver a max of 700mA through the 4 LEDs in series. Also, in the Recom datasheet, there is reference to a circuit where 36V can drive “1-9 LEDs”, so my 4-LED connection is within this range.
I have another driver and another LED, but I don’t want to connect them up until I know what went wrong last time. I’ve just wasted $50 and don’t want to do that again. :banghead:
Any advice would be greatly appreciated. Thanks, JB.
