lonnie_y2002
- Joined
- Jan 19, 2012
- Messages
- 5
Ok guys, what did I do wrong????
I powered on my H6FLEX driver for the first time and I let it come out of program mode. For initial testing purposes, I wanted just factory settings. I am using a rocker switch with an on and momentary on function. When I hit the momentary on, the driver died and will not power back on. (It's fried). I am using a 5S5P 18650 pack with 4X XM-L T6 in series. The LED's and all wiring was hooked up, triple checked, and then the battery was connected. Below is a diagram as to how I had it wired. Do I need to run a current limiting resistor to the SWA?
