Cydonia
Let's make a "light accessory" for an old 9.6volt Ni-Cd battery pack. A simple tough light - consisting of nothing more than some wire, a resistor, and a single 5mm Nichia CS LED. A really dumb simple light that simply works.
Parts list:
Effects of overdriving quality LED's? Read this lengthy article by newbie.
Parts list:
- Male Tamiya RC pack connector - $0.75
- 67 ohm ½ watt resistor (close enough, on hand, so it will do
- 30 inches of 2 conductor 16AWG wire (simply to match the RC pack connector gauge)
- wire crimp connectors
- 3" opaque piece of plastic tube from a roll of dental floss!
- 9.6 volt RC battery pack and charger
Parts ready to go:
LED and resistor with wire leads trimmed to length and ready to solder:
Sand leads of resistor with fine sandpaper and apply coat of solder to leads:
Same preparation with LED:
LED and resistor attached:
RC connector connected to wire with simple crimp connectors:
LED with resistor and solder connections slide into tube:
Nichia CS overdriven hard at about 85ma - slowly warms up, but the 16AWG wire helpes wick away heat.
Who cares how long the LED will last or if it turns blue :nana:
