Ganp
Here's a torch I've been making recently for some fellow flashaholics It's still a work in progress and will most likely have some minor
changes as feedback comes in from current owners. But as it stands, here's the first one, next to a Griffin.
Basically it's a P60 host, but with some extra room inside for custom light engines which can be built with larger heatsinks/LE cans.
To ensure good electrical continuity with this design it is envisaged that a negative contact spring will always be used, even with drop-in
modules which do not normally have one.
All the body parts are turned from the same piece of 6082 aluminium in an effort to get as close an HA colour match as possible. OK, so that
doesn't show in the B&W photo's. :tinfoil: Battery tubes are either 18670 or 18500 sized.
The Kwerk is not compatible with any other flashlight systems so I can build it the way I want, and without the constraints of other system
compatibility, it's easier to make any modifications which may become necessary,
Playing lego light may not be possible, but there are some component interchanges. The tailcap is fitted with a reverse clicky switch but
will also accept a standard McClicky. The lens is a standard 29.3mm x 1.9mm double AR coated UCL, and some custom bezels for the McLux
27LT may fit.
Some more pictures ....
18500 and 18670 bodies with the standard head and custom tri-XPG head.
Tri XP-G/Shark/Remora module and head.
P7/TriFlupic drop-in.
Size comparison with a 6P.
And finally some add-ons - at the request of their owners.
Thanks for looking,
Colin.
27LT may fit.
Thanks for looking,
Colin.
