Protection Circuit
matt304
I built a light using 2x 18350 cells which are unprotected cells.
I have a bit of extra room inside the light to place a low-voltage protection circuit.
Where can I find small protection circuits suitable for cutoff of two 3.7V cells that are placed in series?
Thank you for the link. A lot of good stuff there.
Unfortunately, I don't believe I can use those.
My light gives me a limitation of about 0.7" ID circular to lay a flat board.
The one chip they show for a single cell would work it appears, but all the chips for 8.4V dual cells are long and will not fit the chamber.
Any other suggestions anyone?
Would it be possible to stack two of the circular 3.7V modules, then wire them in parallel input/output?
I'm not sure that would work because even in parallel from the source, they would each still see 8.4V, correct? I believe it's not the voltage that would be halved, but the amperage...
