NewBie
*Retired*
[ QUOTE ]
idleprocess said:
PWM is popular because it's relatively easy to implement, lets you setup a fixed current supply, and makes for relatively easy dimming with perceived "infinite adjustability" without the waste of a pot inline with the LED.
[/ QUOTE ]
Actually, in the case of the LH, for example they use no fixed current supply, its direct drive. PWM does not mean you have any sort of fixed current, it can be done that way, but in many cases it is not, as is the LH.
I still don't understand why they don't sense the battery condition and increase the width of the pulse when dim, to hold the brightness level.
As the battery voltage drops, light output drops, thus it is a non-regulated light, and that is part of what helps it get long runtimes.
It would be alot less with some sort of regulation.
Anyhow, current dimming is still alot more efficient for the luxeon and for the battery.
[/ QUOTE ]
