puzzle
spud
powys
A friend just mailed this:
Hello,
If you have a couple of hours to spare check this out:
http://www.momchill.com/crimson_room.swf
It's a masterpiece
when you finish you can try the viridian room (much
harder)
Take care
G.
I've got past the red room, but haven't had the time to tackle the viridian.
Anyone else seen it ?
spud.
I finished the Crimson Room. I'm looking at viridian room, but am hopelessly stumped. I guess it would help if I can read oriental writings.
VIRIDIAN ROOM SPOILER (don't read if you don't want complete help)
okay... so...
6 pieces of paper with Chinese symbols...
- 1 under the shoes on the small red shelf...
- 1 under the two flattish tan pillows in the corner between the gray and red shelves...
- 1 on the left side of the top of the gray shelf...
- 1 on the very top of the light... you must get it by facing the blue door that leads to the room you knocked the doorknob off from and clicking the light from there...
- 1 more on the edge of the tan border going around the wall... you can also get this one while getting the one on the light or by clicking the top left of the screen from the same vantage point to face that wall...
- 1 in the fridge under the rotten meat...
picture frame...
under the very bottom of the red shelf...
picture of guy & picture of girl...
both in the yellow book inside the bottom of the gray shelf...
incense...
on the right side of the top of the gray shelf...
can of beer...
in the fridge... must be cold when you set it on the gray shelf by the incense burner & bell thingy...
pill bottle with paper with Chinese symbols...
lift the blanket off the skeleton and it's in the right hand...
lighter...
under the trash can... you cannot get it 'til you read about the paper with the hair in it...
paper with hair in it...
in the trash can in the corner where the fridge is... use the light to burn the hair... then continuously click on the blank paper until it darkens completely and you get the message...
key...
screw around with the skeleton's left hand and it'll fall out...
CD...
use the key to open the journal... the CD is in the very back...
red blanket...
click on the skeleton so you can see its ankles... then click the blanket around the ankles...
green domino puzzle...
click the red blanket to read about it, and while it's on the screen continuously click the blanket 'til it rips completely and you can click the dice puzzle inside...
bike lock...
it's on the skeleton's ankles... click it... the combination is 0617...
then match the numbers on the paper that had the hair in it to the Chinese symbols from the paper in the pill bottle... then match those to the numbers on the green domino puzzle... you'll be alternating from the hair paper to the bottle paper to the domino puzzle quite a bit... i got out a piece of paper and drew a tic tac toe thing with 4 columns & 4 rows then just filled in the numbers so i didn't need to use the paper that had the hair...
after you've got it all matched up it will automatically turn into a box... arrange your little shrine on the gray shelf... make sure the beer is cold... light the incense... ring the bell... set your spirit free...
