PX200-HID . . . Beamshots Added
petrev
SW England
Hi
PX200-HID
200W Regulated Ballast - Custom Build Assembly
Dimmable to 120W (further dimming possible but not advised)
~1 Hour Runtime ( tested at 58min ) 8800mAh 29.6V Nominal (33.6-24V)
16000 Lumen Osram HMI 200W/SE GZY9,5 VS1
>90 CRI Daylight 6000K
Focusable 8" Mirror-Lamp assembly
Custom Fitted High Voltage HID GZY9.5 Bulb Holder
Hot Restrike Ignitor ( Very Warm Re-strike !)
Thor Host - (Ballast +Mirror System fit many 8" Thor-Type Hosts)
Self-Contained (Battery On Board but could be remote if required)
All-Up Weight approx. the same as a Thor X10
Industry Standard Ballast Connectors
KIT Thread
+++ PX200 HID KIT +++
Tested Peak-Beam Lux @ 2.5m
POB-4300. 70 KLux (Small Hot-Spot)
LK14 . . . 105 KLux (Huge Hot-Spot)
PX200 . . 220 KLux (Medium Hot-Spot)
Ballast will be Black HAIII or Olive-Grey HAIII :popcorn: Someday . . .
Inspiration by EZ78 and RA
Cheers
Pete
Beam-Shots follow . . . Now
Google-Earth
Pylon @ 240yds
f4 - 1/2sec - ISO100 . . . Looking Down Beam to Pylon (Slightly Misty)
[URL="http://imageshack.us"] [/URL]
f4 - 1sec - ISO100 . . . . Side Beam to Pylon
f4 - 1/2sec - ISO100 . . . . Park
3 Beams f4 - 1/6Sec - ISO100
Misty Moon
Hi
Video of focusing
http://www.mediafire.com/?119wbcwneyy
Note: Focusing is a "preseting" operation at the moment and cannot (yet) be done during normal use. Access is via battery compartment.
Cheers
Pete
Re: PX200-HID
''mmmm'' beamshots
Re: PX200-HID
Oh yeah. I like this one! :twothumbs
How long is the arc gap in that bulb? Focusable lamp assembly sounds good. I am quessing you can get pretty intense beam with this one if the bulb is well centered. Well done pete. :grin2:
Re: PX200-HID
Hi petrev,
looks nice, your creation, nothing off the shelf, a true custom design.
Some questions:
- I guess your battery consists of 8 series connected li-io or lipoly?
- Is the ballast electronics completely self designed? If so, where did you get the knowledge required do do such a design (bulb characteristic, ...)?
I thought several times of doing a multi-100W HID ballast fed from a 2s or 4s lipoly pack but decided then do do a big LED light first...
- What do you mean with "Very Warm R-Strike" ?
- How do you charge the battery (balancer or cell per cell)?
Regards,
Holzleim
Re: PX200-HID
Hi EZ
5mm Arc Gap
Lamp is designed for the film industry so has very good CRI
Seems like a very good intense hot spot when fully focused - Focusing is from the rear, through the battery compartment (until someone points me to some way to motorise it !) and can go from Donut to loose spot to tight spot to just slightly over inserted. Had lots of fun getting the bulb not to hit the front glass ! ! !
Hi petrev,
Some questions:
Regards,
Holzleim
Hi Holzleim,
Actually a German ballast-module that I had to case and connect etc. Hence - Custom Assembly.
Building the actual electronics would be way beyond me !
Lots of Off-the-shelf bits in a custom heatsink-case (but it was quite some effort to get all the parts together)
Battery is 4p8s LiIon (actually 2x 4p4s connected in series) fully balanced.
I charge them one at a time using an FMA Balance Pro6S and they take about 2.4 hours each at 4A charge rate - could charge at 8A but my power supply is too small to cope !
"Very Warm R-Strike" - Ignitor is Hot Re-Strike but you have to wait about 20-30 seconds for the inner envelope (arc chamber) to stop glowing before it will catch the arc again.
Cold-Off to Full Power seems to be about 20sec.
It's fun to have about the same output as an LK14 but that runs for an hour.
I'll try to get Beam-Shots and post more pics when I can . . .
Cheers
Pete
Re: PX200-HID
Thanks for your fast reply.
Could you provide me with the exact type of the ballast and the source where you got it?
Cause we are building a house this year I don't think I'll get the time for a big HID project after I finished my big LED light(should be within the next 2-4 weeks), but your thread refreshed my interest in a >500W handheld HID light.
But despite the fact that I'm an electronic engineer I think I'll have to collect a lot of very specialized knowledge to design a custom ballst the operates a >500W HID from a reasonable voltage that can be sourced by 2-4 series connected lipo cells (perhaps 4p4s of 5Ah cells).
Most buyable high power ballasts are made for either 110V or 220V AC input.
Re: PX200-HID
:takeit: :paypal::goodjob::wow:
There aren't enough icons to express myself further. :nana:
Wow - very nicely done! Let me know when you want to sell this one. :)
- FITP
Re: PX200-HID
Hi Holzleim,
Sorry -they don't do any ballasts bigger than 200W for DC battery power ! ! !
Very difficult to find DC input high power ballasts at anything but extortionate Film Company prices . . .
Hi Ken
Help ! ! !
No Permit ! ! ! :naughty:
Re: PX200-HID
- FITP
Hi FITP
:thumbsup:
I am thinking of doing some sort of "KIT"
Ballast + Mirror Assembly + Wiring Harness
Just add Host, Lamp and Battery and a bit of Dremel sweat
Cheers
Pete
Re: PX200-HID
Hi FITP
:thumbsup:
Cheers
Pete
lol - a DIY kit? About the only portion of this setup that I feel confident adding is the "sweat" part. ;-)
(On the other hand, if you decide to sell a complete turnkey package, please do not include the sweat. It doesn't ship well, and would be awkward to explain to my wife.) :whistle:
Seriously, if you decide to sell this whole package at a later date (either as a one-off or as a semi-production item), drop me a PM. It's amazing! Phenomenal work, petrev!!
- FITP
WOW, great work petrev! Your PX200 HID monster has a really amazing beam and THROWS. I love the sky shot with the lights pointing up into the sky. The beam collimation of the PX200 is incredible!
Thank you for sharing the pictures and beamshots of your awesome light.:thumbsup:
HOLEEEEY &^%$, you better not fire that thing up if there's any burning restrictions in the area!! Well done!
I'll echo what others have said; that beam collimation is incredible! A beast that goes toe-to-toe with the LarryK14, but increases the runtime bar by 6x is just amazing.
Incredible work. :twothumbs
- Dan
Gotta love the high wattage HID's! Another great job Petrev! I love the stuff you're making! If you're serious about a kit, I'd buy one in a heartbeat! And keep making more neat stuff!
Looks very good. Very nice tight beam. Almost supprisingly powerfull when compared to the POB and LK14. I think my 400 watter is wasting more lumens as side spill. This does not seem to fall that much behind in performance. And totally self contained setup. Exellent job!:D
