Sold/Expired +++ PX200 HID KIT +++
petrev
SW England
Experimental 200W Hand-Held Self-Contained HID Spot-Light
PX-200 The most powerful self contained HID spot light in the world with 1 hour runtime (battery dependent).
Completed mod - Like this one in the original thread with beamshots
HERE with D-Luxe HeatSink+Fan Ballast Case
Standard Kit will be Fully Assembled 200W Ballast (in Choice of CaseA-HSF or CaseB-SF both with fan.switch.fuse etc.)
+ Ignitor
+ Mirror.Lamp-Holder.Focusing-Assembly
+ Wiring Loom with Breaker Switch
+ Choice of connections
. Lamp-Ballast (Industry Standard Plug or Fixed Cable)
. DC-Ballast (Industry Standard Plug or Fixed Cable)
I am currently building the simpler Basic Fan-Case that should also be an option choice.
Modder just add HOST, LAMP, and BATTERY
All fixings provided.
Dremel or similar required (or be very good with a Swiss army knife !)
Drill required for cable entry holes and Breaker-Switch.
Full HOST modding details, descriptions with photos, and specifications for LAMP and BATTERY provided.
Host modification is very straightforward and bulbs and batteries are readily available from the usual sources.
Disclaimer:
Kit supplied for personal experimental purposes - no liabilities implied or accepted.
Danger - HID Lamp contains HIGH VOLTAGE and cannot be used in Damp, Wet, Flammable or Explosive Gas or Powder/Aerosol environments.
Emission of Visible and UV radiation - do not look directly into light
(16,000 LUMENS)
(Peak-Beam LUX @ 2.5m = 232,000 LUX)
Do Not touch Glass or bezel fittings - VERY HOT !
Additional forced cooling (Lamp area) may be required for extended runs in higher ambient temp. zones) 30min @20C tested OK
I am still exploring the limits of this experiment . . . so can you !
Kit Costs From $787 to $933 depending on Case +option choices
If you're interested then post here to reserve a spot. I'll collect the full funds within weeks.
Pete
Res.
KIT
1. modamag (PM)
2. JimH (PM)
3. ? ?
4. ?
5. ?
Did this ever happened? Do you have extra kits? Petrev, send PM if you have components for sale.
Hi
Thanks DM :thumbsup:
JimH and Modamag now have kits for a build of their design ? ? ?
Kit available depending on options
Cheers
Pete
