i have forgot the diameter of the glass that i used /ubbthreads/images/graemlins/ohgeez.gif
but now i measure the internal diameter of the bezel: the 6p is 28,0mm so i think that i have used a 28,1mm glass. the TT 1L bezel is 29,3mm so i think that i have used a 29,4mm glass. this glass go in with a pressure on the bezel so there is a risk of broke... but if you can put in after installing the gasket the glass become very stable (there isn't risk of lose...)
the glass that i use is the same of the common watch, there are all diameter and all thickness and the cost is quite low (5-10 $ depending on the size)
i'm thinking to use also sapphire glass, they are 4 time stronger that tempred glass but the cost is much high and is difficult to find all diameter...
