Hi!
Im new to this whole wiring LED's thing. But have some basic knowledge!!!:thinking:
I have 12 LEDs in parallel, here are the numbers:
Power source: 12Volt Motorcycle battery (will be installed on a bike as well!)
LED specs:
LED specs:
Emitted Colour : Yellow
Size (mm) : 3mm
Forward Voltage (V) : 1.8 ~ 2.2
Reverse Current (uA) : <= 30
Luminous Intensity Typ Iv (mcd) : 4000(Typical) ~ 5000(Max)
I used this site to calculate the resistor needed for my 12 LED parallel circuit. http://ledcalc.com/#calc
Values I plugged in:
Supply Voltage
VOLTS
Voltage Drop Across LED
VOLTS
Desired LED Current
MILLIAMPS
How many leds connected
The answer was: 33Ohm - 5Watt resistor.
Everytime I connect the resistor and turn on the power, all LEDs blow instantly. Is the resistor too big? Am I not using the right numbers in the formula??
Any ideas are appreciated.
Dennis
Size (mm) : 3mm
Supply Voltage
VOLTS
VOLTS
Desired LED Current
MILLIAMPS
Dennis
