SilverFox
AK645 sent me 2 UltraFire 18650 2400 mAh cells to test. These are protected cells.
I opened the package and checked the voltage of the cells. Both were below 0.1 volts. I wondered if the protection circuit had kicked in, but that would mean that the cells had self discharged. How old are these 2400 mAh cells anyway? Perhaps AK645 can answer that question.
I put the cells in my Pila IBC charger to charge them up. The Pila IBC refused to recognize them or charge them. At this point I contacted AK645 and told him that he should send them back for a refund. At the same time I tried to recover the cells by charging them at 0.1 amps. The voltage gradually rose to the point where the Pila charger would recognize them and charge them.
The cells warmed up on the Pila charger, so I moved it outside as a safety precaution. After a couple of hours I pulled the cells and decided to discharge them. The cells would not sustain over 0.1 amps. When I exceeded that current, they immediately shut down.
I told AK645 that the next step would be to remove the protection circuit and check out the bare cells. He told me that he was not planning on sending them back for a refund, so I should proceed.
I removed the protection circuit and did a 2 amp discharge. The initial cell voltage was 4.0 volts, so I did not expect full capacity. During the discharge the cells heated up to 130 F and were continuing to heat up at the end of the test, and the discharged capacity came in at around 1150 mAh.
Since I started with cells at roughly 80% of full capacity, I was expecting more from these cells. 80% of 2400 mAh is 1920 mAh. My 1150 mAh works out to around 60% of the capacity.
Not only did the protection circuits go bad, but the cells also went bad.
I see UltraFire cells mentioned from time to time. Is this an isolated incident? Have others had "issues" with these cells?
Tom
Tom
