I was wondering specifically about Surefire lamps (I use the P60 quite a lot) but I suppose this would apply to any lamp.
So, when a bulb life expectancy is given, how is that estimated, lots of short bursts, or constant use? The P60 for example, I'm not even sure what the expected life for it is, but whatever it might be, do Surefire establish that assuming thousands of few second long uses, or do they assume run for an hour, change cells, run for an hour, change cells etc and that's how many hours you'll get.
Another way to ask the same thing, what would reduce a bulb more, 1000 bursts of 3.6 seconds each with a pause between to cool, or a straight 1 hour run?
Thank you.
Thank you.
