Question about SF 9N lamp module
HenryMudd
Omaha, NE
I have an older Surefire 9N. Does it take the same lamp module as the new 9AN? Also I need a new battery. I assume that the B90 is the one I need?
I don't know. I'll check mine tonight. I know the 9AN uses the N90 LA, and I swap batteries between my 9N and 9AN.
The correct lamp assembly for the 9N is the N90 - the same as for the 9AN, the B92 rechargeable battery was discontinued and replaced by the B90. So the B90 will be the right one for you.
Klaus. /ubbthreads/images/graemlins/wink.gif
Yup same lamp, BUT the older lamp assemblies, when the hi output bulb wsa activated, the low-output lamp was not. On the new lamps, both lamps light-up when the hi output lamp is activated.
--dan
