bwcaw
My dad bought the parts for a prt head from the sandwich shoppe with a downboy 700 driver board. I assembled the board into the ecan just like the instructions on the shoppe say, and the board tested out great. I potted it and put hooked it up to the lux III that we were going to use, and still fine. Finally I hooked it up and put it into the prt head, and for some reason it wouldn't work in there. I then took it out and checked all my connections (which entailed removing the potting /ubbthreads/images/graemlins/icon8.gif) and they were all fine. I then tested the board with the potting out of the ecan and it lit the led very dimly. Why won't it light full brightness? It is very frustrating to spend almost 3 hours assembling a light only to have the board stop working when you are almost done! What is the problem here? And is there any fix?
BTW I did test the led on my bench power supply and it functions properly, it is just the board that bad.
Thanks for any info you can provide! /ubbthreads/images/graemlins/grin.gif
