I wnt to use 3 V rechargable for my Fenix PD 10,Whats the difference between Tenergy lifepo4 750ma vs tenergy 3v rcr LI on 900ma. Are thier Ma ratings accurate? What would be the better choice.
Thanks for the info guys ,but I think I will stay with primarys.It seems like the best choice for this light.
I have to say that as far as the 3 volt LiCo cells that I've used (not Tenergy's), they do quite a bit better than that, but are still less capacity than an AW RCR123 cell. The rest is true however. LiFe cells struggle to have half the capacity of LiCo cells, it's just the nature of LiFePO4 chemistry. Also, LiCo cells in general, are only about half the capacity of lithium primary cells, at best. Their higher voltage offsets this substantially though, the actual "power" (Wh) thus, is a bit better than that.3) Their capacity is abysmal at best. They are as bad as 1/2 the capacity of the awrcr123's that I sell and as bad as 1/4 the capacity of lithium cr123a primaries.
BTW have you ever used 3V rechargable and lost some/all modes?Im just curious if its likely to happen in most lights.
I'd like a keychain LiIon light and have considered the Quark Minis. But, they have a runtime on hi of just about 30min and that's pushing LiCo cells harder than I'd like. Better than 10440s in my L0D but still, a regulated 1A on hi would be my ideal.
I ordered (and am trying to cancel) some Tenergy 750mA LiFePO4 cells that for some reason have a warning about not using the WF charger. Not sure why, something about them being LiFePO4 with a series .2V diode? Strange and very confusing even with warnings.
