Question -- Other lights that fit the ARC LS batt
Status
Not open for further replies.
wwglen
NC
I had my ARC LSHS dissapear at work. My fault because I forgot it by the equiptment I was working on. When I went back the next day it was gone and of course NOBODY saw it.
As a result I am left with an EXTRA AA clicky and 123 twisty.
If there any other heads that will fit? it seems a shame to have the bodies and no light to go with them.
Thanks,
wwglen
The threads are the same as the Surefire E series. But Surefire has fewer threads above the o-ring and the battery sits deeper in the body. You could perhaps set up the 123 twisty to work with a KL1 and a CR2 battery, for example, or the AA clicky to work with a KL1 and 3 @ CR2 batteries or a Li-ion AA, but it would be a bit of carefull work cutting the threads shorter. You could also do similar adaptations to the packs for use with the E series compatible heads the Sandwich Shoppe sells. Unless you really have the modding bug, I would suggest saving them until you get another LS or selling them on BST.
Re: Question -- Other lights that fit the ARC LS b
[ QUOTE ]
wwglen said:
<snip>
[/ QUOTE ]
The head of a CNC-123 will mate to the bodies of ARC LS lights. They wont screw down all the way, but they will work (I just tried it).
Status
