chrisse242
My girlfriends sister asked me for a good led-penlight and after I found kiesslings comparison I decided I didn't want to recommend any of those he reviewed. A two cell arc aaa with tailswitch was what came to my mind. No common mod was available at cpf and peter doesn't really seem to have the time to produce the two cell bodys he once presented. I knew the aaa-head is capable of running on two aaa's and started thinking about how to build my own body. I had to stop since I had to go to buy some food and at the shop I found a cheap incan penlight produced by Varta. I bought it and back home just sawed of the front part where the bulb protrudes. The head of the arc can be pressed into the body and sits in there quite good. I dind't want to have anything permanent because I want to keep my own aaa the way it is now. As soon as I receive an extra head I will think about a way to attach the head permanently. Can anybody tell me the thread size for the aaa? If threading the body doesn't work I will try to epoxy it in. For now it works like charm. The switch is a reverse action clickie ( on / momentary off / off), the light seems to be a bit brighter on two aaa's but didn't get hot after about ten minutes of runtime. The intended use of my girlfriends sister is no longer than a few minutes at a time so this will be fine.
Well here is what you all are looking for: Pictures!!
stock light:
stock light:
