brightnorm
- Joined
- Oct 13, 2001
- Messages
- 9,027
Spring tension on the E2E’s Z52 LOTC can be quickly and easily adjusted to your preference.
For less tension use the butt end of a small screwdriver or similar object to fully compress the spring as far as it will go. Hold for 5 seconds. Try it out. Repeat if necessary. The spring's memory will want to restore its original configuration so the procedure may have to be repeated later. For a more durable fix simply extend the compression period to 30 seconds or longer, making sure that the spring is fully compressed.
To increase spring resistance do the opposite but be careful not to overextend it.
Brightnorm
Brightnorm
