quick resistance/current calculation question
moon lander
boston
(Vs-Vr) / I = R
Where:
Vs = Voltage supplied
Vr = Voltage required
I = Current draw of component in Amps
R = Resistance needed
all above from here: http://flashlightreviews.com/qa/resist.htm
the question is: is Vs supposed to be the supplied voltage including voltage sag (in the case of using batteries)? for example, when i test a pair of cr3023s in series, they say 6 volts. if i do the same test while they are driving an led (under load) they read a total of 4 volts. do i use 6v or 4v as my Vs? also, do all battery types experience voltage sag?
thanks,
Lucas;
The voltage sag is due to the resistance of the batteries and wiring.
All batteries have some series resistance.
The drop from 6 to 4 volts seems pretty large to me, but I guess it's not too extreme for that size battery.
The #18650 lithium-ions I use typically have 100-200 milliohms resistance at the 700ma current load I operate at.
Larry Cobb
LEDite said:
Lucas;
Larry Cobb
thanks larry,
so based on your answer i assume i should use the original voltage in the calculation, not the sagged voltage, since the sagged voltage is dependant on the rest of the circuit.
-luke
