Re: **MODDED** Rayovac Lantern Moddable?
I got a couple of Seoul emitters today so I went ahead and replaced the LED array with 1 U2SV0H emitter. The swap was pretty straight forward. I would have preferred a star but all I could find was an emitter. I had a small piece of aluminum so I hacked, and I mean hacked out a quick sink.
Firstly, remove the batteries and the 3 screws holding the innards in the housing. Once the screws are out, gently pry with a small screwdriver or similar between the outer case and the battery carrier. The batt carrier will pop right out.
Drill out the 2 rivets holding the array down. Take note of the polarity.
The array is held down with some kind of adhesive, I used a sharp and narrow knife blade and just slid it under the array to loosen it. Cleaned up the remaining adhesive from the pedistal, put some thermal paste down and screwed the new emitter in place with 2 small screws in place of the rivets.
Finally, put it all back together and enjoy the new light
I was hoping the new emitter was a little warmer but I can't really tell much difference. The output seems to be a little better but not by much. If I can find a warmer tint, I think I'll do it again. The tint in the picture is just a little bluer than reality.
*Edit* After using the lantern and comparing it to another, it is definatly brighter and a little warmer in color. Also I was looking at the OEM emitter array and discovered on the bottom of the LED base, there are three resistors. I suppose one could change the value of those to get a little more or less light from this lantern.
