Real World Review – Rayovac Sportsman Xtreme
zespectre
Lost in NY
Real World Review – 2/16/2008
Rayovac "Sportsman Xtreme" 3watt LED Flashlight
Model: SELUX2AA3W-B
http://www.rayovac.com/flashlight/selux2aa3w-b.shtml
Howdy all. I dropped off the forum for a while (moving and new job has kept me fully occupied) but continued to lurk here and there. Other things were demanding attention and money so my beloved illumination tools simply had to take a bit of a back seat. Plus I have really good flashlights so I was able to scrimp by for a while. But as we all know the bug NEVER really goes away <grin> so here we are with the next (and LOOONG overdue) "real world review".
A quick recap, the "standard evening walk" has changed somewhat over time but the current targets are still very similar to the ones I used to use back in Arlington.
The New "Standard Evening Walk"
The evening walk takes place over either a 1.5 or a 2.5 mile loop depending on the whim of my wife <grin>. It begins on a well lit and well paved street, proceeds parallel to a large, unlit, cemetery, and then into an unlit neighborhood. We then usually cross a short gravel path into another unlit neighborhood and back down a steep hill to a regular lit/paved area. In the course of these walks I have chosen 6 "standard" targets to compare flashlight capabilities.
#1) The fence at the end of our parking lot (approx 50 ft). Weathered brown wood that makes a good test of color rendition and contrast.
#2) A light grey mailbox from 30 yards away.
#3) Cemetery (how many rows of headstones can I illuminate) distance test.
#4) Thick shrubbery along the edge of the walkway (approx 6 ft away, testing penetration vs. "bounceback").
#5) Red fire hydrant and three phone poles roughly 50 yards away on an unlit street (Can I see all?)
#6) Short but steep downhill gravel path with bad sideways crown (the "confidence" test).
Initial Impression(s)
The Ray-O-Vac light is fairly small and slim and feels well made. At 5.5" long it is pretty typical in size for a light that runs on 2xAA batteries. The aluminum body has a beautiful and interesting form and the quality of the machine work and assembly is very high with some sort of pretty grey/green anodizing. The body is fairly thick and seems very durable. The light has a clip-on style pocket clip with a good amount of spring and also has an included lanyard secured to the light by a plastic ring that is secured by the tailcap. One could easily remove or re-install the clip, lanyard, or both at whim.
The switch is your standard "press for momentary/turn for on" style tailcap with a rubber cap that protrudes slightly so the light isn't really able to stand on the tail. The switch itself is actually pretty nice and requires only minimal pressure to activate however this may also make the light prone to accidental (momentary) activation and you do have to unscrew the tailcap quite a ways to disable the light. I don't feel this is actually a negative issue at all, just something to note.
The body of the light has a rubber "o" ring and although I didn't test waterproofness I'm sure this light will be at least "dunkable". The light is listed as having an "adjustable" head. In fact it can be unscrewed all the way off, revealing another nice "o" ring and the well mounted Luxeon emitter. If you want to go blind you can use it as a candle in this fashion. In point of fact, other than having a "candle mode" I can see no function to unscrewing the head as it has almost no impact on the focus of the beam.
With the head screwed all the way on the deep reflector produces a very nice beam, biased towards throw but with a nice transition into a very even spill. The color rendition on my sample was quite white with possibly a (dare I say it) yellow component. In other words not nearly as blue as most of my other LED lights.
The light claims to have an output of 80 lumens (I have no way to test that) and also claims to have a regulating circuit (I'm testing that right now).
Balance, retention, and single hand operation of the light are first rate due to it's body styling and with the lanyard attached there is absolutely no drop risk. The light is also extremely sturdy and I seriously doubt dropping it would do more than mar the finish unless a rock hit the glass directly.
The switch was easily operated one handed though the threads were a bit dry/stick so I touched them up with lube and then the tailcap rotated smoothly.
I lean towards throw so the slight bias towards throw that this light has was right up my alley. The side spill is very usable, giving me a secure feeling on the "confidence" areas of my walk with only a slight "follow the bouncing ball" effect from the hotspot .
This 2xAA light stunned me. It outpowered the old but trusty Gerber LX 3.0 AND my favorite walking light the Inova T4! Okay I have an older T4 with the TIROS optics, but not much has overpowered this light and NOTHING in a smaller package has done so until now. Hrmmm, a $100 light shown the door by a $25 light. Ahhh progress <grin>.
This light did a fine job of illuminating all distance targets.
Targets
#1) Color rendition was as good as any LED light I've seen.
#2 was an easy spot due to the strong throw of this light.
#3) distance was good and I could see 3 rows (approximately 30 yards)
#4) Decent "punch through" of the shrubbery with very little "bounceback" to blind me
#5) Easily enough power to see at 50 yards. I have no way of verifying the 80 lumens claim but it looks good to me!
#6) "Confidence" trail use was very good with only minimal "Follow the bouncing ball" effect.
Summary:
Well I'm going to start the summary off with a complaint. This light is just too damn bright for up close work :whistle:.
I stick by my standard claim that any light above 50 lumens needs a "low beam" so you don't burn out your eyes when trying to do close-up work.
Okay so much for the complaints section, now about the rest of the light. Super bright, nice beam, strong construction, pleasing ergonomics, lifetime warranty, decent price…. You know where I'm going
STRONGLY RECOMMENDED.
(Someone's gonna flame me for this statement, but as far as I can tell this light is sneaking into Surefire territory for quality and performance!)
EDIT: Apparently this light is actually a Nuwai X-3 rebranded. Interesting, somehow I never knew this light existed before this week. I guess I'm a bit behind the times. Still my review stands for anyone who wants to get one :)
Thank you for the extensive review, you put quite a lot of work into it.
I read about the Rayovac so I checked it out at Wal-Mart and I was
impressed. A nice light for a good price, but I did not buy it immediately.
I went back the next day and they were sold out! As soon as they
re-stock I will get mine. I really like the green color and I have read
only good things about it.
Ditto...for $25, a very nice light indeed...It's my primry EDC, with an SF 6P as a back-up. It does start acting funny when the batteries start dying down...but give a solid 1.5 hours of blinding, consistent light. I'm thinking about getting a second one...
Great review! Any chance you could get pictures on another evening walk? I've got a display case of Sportsman Xtremes (Thank you ebay) and I've been giving them out left and right as gifts. They outshine my surefire m2 (p60) and are cheap enough that if they get lost, it's no big deal.
-Max
Picked up a Sportsman Xtreme at Walmart yesterday for $19.95. Tested it with Energizer 2500 Mah NiMHs and stopped timing at 3 hours with very little fall-off.
This is a great little light. (Maybe some of the credit should go to my 808M charger!)
Sorry, the evening walk is exercise so I try to keep moving. I doubt a "snapshot" would give you a very good idea of the area. Maybe sometime I'll do some daylight shots just for reference.
Did a runtime with both alkalines and with NiMH batteries. It pretty much duplicated the graphs posted HERE so I'm not going to post mine. I was running a pretty new pair of 2500mah batteries and got 2hr 15 min runtime out of my unit.
Did you get the 1 watt or the 3 watt version of the light? They look almost exactly the same, but the 3 watt would only last a bit over 2 hours on rechargeable AA cells.
My 3 watt also has a slight purple tint, but I only notice it when I look for it (so I stopped looking for it, DUH!).
I also really like the alien, futuristic look of the body which looks like it would be right at home on a Klingon Bird of Prey. (Please don't label me as a trekkie. I watched the TV show, saw some movies, I assure you- purely by accident.)
I'd love to put in a UCL lens I bought for it, but I'm afraid if I try to remove the plastic lens, I'll break the reflector. I wonder- has anyone been able to replace the lens?
The only thing i do not like about my light is that it shuts down when the battery gets low. This is good for nimh batteries but not if you need some light.
Yep, i have both the 1-watt version, and 3-watt.
My 1-watt is labeled Ray-O-Vac. 3-watt is Nuwai X-3.
Really like the secure, "hand-grenade" grip of these lights. :thumbsup:
When TerraLux introduced their branded version, with a Rebel emitter,
i kinda' assumed it would be this same body.
But no, the TerraLux ( called the TLF-3L2AA ) has a slightly re-designed body,
with a slipprier finish. :-(
On the other hand, the TerraLux does have a great Orange-Peel reflector now,
and the glass-lens in now securely mounted,
not simply glued-in. :thumbsup:
Gotta' love these "bargain" 2-AA flashlights !
:twothumbs
_
I picked one up at Walmart 2 weeks ago as the first taste of my new drug.
Nice little light even though it's not the newest/most efficient LED out there. It feels good in the hand, and is nice and bright. I did add a wrap of paracord on the body that made it even easier to hold in a Roger's/Surfire grip. Close to the output of my Surefire M2 with p60 although less warm. The momentary switch was a real selling point and is nice to operate. It's not too sensitive or too tight feeling to use. That said the switch mounting feels kind of loose in the tailcap. Its fine when screwed down ready to be used, but when locked out it feels sloppy and I worry about it getting damaged in my pocket or bag.
Nice light for 25. Its found a number of uses already.
As I've mentioned in other threads, I really like my 3 watt sportsman xtreme. It was really the light that got me set off on the Surefire tangent thats costing me so much of my hard earned money. The only thing I dont like about it is the fact that I get so little from the regular akaline batteries (I have yet to invest in some AA lithiums). About 45 min to 50%, than another 25 minutes until die off.
Pros: neat anodized (type II), futuristic body form. bright. cheap. good throw. Rivals my p60L for brightness (loses out, but only slightly)
cons: cooler tint (slightly purplish), much cooler than my slighty blue/green p60L dropin.
A couple of weeks ago I came across a whole end cap of these lights along with the Sportsman Extremem headlamps at a Tulsa, Ok Wal-Mart for $9.00 each. Wal Mart must be clearing them out, so be on the look out.
I snatched em all up to give as Christmas presents.
