I used my Pelican M8 8020 Recoil LED in the fog at 0 dark 30 this morning. Works as advertised.
http://www.flashlightreviews.com/reviews/pelican_8020.htm
garageguy said:
Actually, fog and smoke machines are completely different from each other both in the composition of the cloud they make and in the individual properties of each cloud.Outdoors Fanatic said:Aren't fog machines fueled my chemical fluids? That's different than the water mist presented in natural fogs. Great shots though.
Pretty good explanation. I thought dry ice was totally outdated... Really interesting piece of info.Sub_Umbra said:Actually, fog and smoke machines are completely different from each other both in the composition of the cloud they make and in the individual properties of each cloud.
Smoke machines do use a chemical fluid to produce a smoke that:
Fog machines make their cloud by dropping dry ice (frozen carbon dioxide) into boiling water to produce a fog that has some properties similar to real fog:
- Doesn't smell bad
- Isn't generally irritating to eyes or lungs
- Is formulated to resist disipation for as long as possible
Sometimes a theatre's tech crew will combine the two different effects by running the output of a smoke machine through an apparatus that cools it before release to create a cooled smoke that has some of the properties of both smoke and fog. It will hang close to the floor for a while (until it warms up) and will resist dissipation.
- It's colder and denser than smoke, so it hangs closer to the ground and will flow over obstructions like fog.
- It is made up of carbon dioxide vapor instead of water vapor.
- It dissipates more rapidly than the output of a smoke machine.
- Fog doesn't leave a slippery residue over everything after repeated use. This makes fog sometimes preferred for shows with a lot of action or dancing.
