Reccomend me RCR123A
Albinoni
Banned
Perth, Western Australia
Can you pls reccomend to me good quality RCR123A type batts, been thinking of trying one of these in my Fenix P1D torch, I'm too scared to use cheap quality RCR123A's.
Keep in mind that max input voltage for the P1D is about 3.3v. Anything higher and all modes look exactly like turbo.
Ok are you saying dont use RCR's than and just stick to normal CR1213A's?
Re-phrase... "Powering it with over 3.3 Volts will loose the multi-mode and default it to Turbo."
I have seen 3.0V 16340 sized rechargeable cells, that might be a better alternative.
And here I see two different systems: RCR123 3V and 16340 LiFePO4 at nominal 3.2V. Both of them are excellent in my Fenix P2D.
Wulf
Whats the difference between the 3.0V 16340 and RCR123A, are they both the same size, they both are lithium as we know but can I use a 3.0V 16340 in a Fenix P1D ?
