It has an R2 LED drop in. I was hoping the switch to rechargeables would maybe increase the output some as well.
If you don't mind the light being a litter longer, the use of the A19 cell extender will allow you to use two 17670 cells which will provide plenty of power and runtime for your P91 LA and other after market lamps.
My favoirte combo for incan, gulit-free setup without too much of a frankenlight look.
From what I've read here, it's generally considered that a 4.2v LiIon sags to ~3.7v +-0.1v when under a moderate load. Same thing for a 3.0v (nominal) CR123, 2.5v +-0.1v. I've also read (from SilverFox I think) that a CR123 under a very severe load can sag to as low as 2.2v.Kestrel, I always thought a 17500 is 4.2v and a CR123 3v, please correct me if I'm wrong.
KJB32, I have a couple of R2 dropins, they run on 3.7 to 15v, so they can be run on a wide spectrum of cells. I'm not sure if you have the same dropin though.
So would RCR123's fit? I believe they are the exact same size as CR123's, correct?
