pobox1475
The best piece of electronic gear I have seen are the rechargeable alkaline batteries from Rayovac. I have used them in D,C,AA and to a much lesser degree AAA. When fully toped off put out >1.5v and can be charged hundreds of times and thrive on frequent charging. The D's and C's have been used in portable satellite boom boxes for entire afternoon outings. I did however render a set of 6 D's nearly useless due to a parasitic drain in a radio as it drew power when switched off. I now take one cell out to break the circuit.
Positives:
1) High voltage output compared to NiCd & NiMH
2) Long life if used with care (see negative below)
3) Can be topped off so you know they are always ready to go
Negatives:
1) If allowed to completely discharge their usable life span is diminished (I use back up system and switch after 1/2 way usage)
2) Discontinued products and are harder to find. Similar cells marketed under GRANDCELL name that I have but not used enough to give an opinion.
3) Use specific charger technology, but will charge NiCd & NiMH as well.
Positives:
Negatives:
