Recharging Lummi Raw with regular charger
not_waterproof
T.
I have a Lummi Raw and the charger below.
I can't use the Nano charger because I'm in Germany.
I've tried to come up with a way of charging the batteries but nothing I tried worked.
Does anybody have a solution?
Please post in the correct place - I'm moving this to the Batteries section.
Are those 10280 or 10180 Li-Ion cells? If so, they will need a proper charger designed for Li-Ion chemistry. What charger is that? The Nano charger should work in Germany - why do you think it won't?
Incidentally, if that is a BC-700, as Stereodude says, you must NOT attempt to charge Li-Ion cells in it. It's for NiCd and NiMH only.
Are the Nano chargers single-voltage or world compatible? In the latter case you don't need a voltage transformer, you just need a $1 plug adapter...
Ok that's right. Now that I looked at the website it's a LiIon.
Thanks for the warning.
Now where do I get a UK travel adapter from?
It sure looks like mine, so I'd definitely say it's a BC-700. :green:
Do not put Li-Ion batteries in it! :ohgeez:
