clearly uses multiple dies so it's lifespan will be much longer.
The demand for 3mm and 10mm leds is just not the same as the 5mm standard so you'll find most innovation there. That being said I got one 10mm from DX in the form of their 10mm coincell light and I'm pleased at the brightness and focused beam. It's as bright as the single die 22,000 MCD 5mm leds and clearly uses multiple dies so it's lifespan will be much longer. The beam is much smoother and less blue (green tint) which i find more useful. I can recomend that you pick up a set of ten to try out for $2.49 shipped and see if you like them.
http://www.dealextreme.com/details.dx/sku.3190
Oh, I forgot to say
Welcome to CPF!!!
Oh, I forgot to say
Welcome to CPF!!!
Check with DX, this LED size is actually 10.5mm, was told by DX that it will not fit in the normal 10mm LED keychain casing.
Anyone else has any recommendation, looking for 10mm LED pure white to mod my 10mm LED keychain?
Thanks pal.
Does anyone know what is the brightness of this 10mm from DX in term of mcd?
