Recommend flashlight for camping/all-purpose
Agro
I've read a few threads on here and the flashlights I think so far to consider are: Something from Fenix (say TK41 or LD41, etc.) or from Olight (maybe M30 or M3X, but may be too much?)
One thing I wondered though is, can I find a flashlight that meets all these requirements below, but also runs off of say a LiPo battery? I have a 24v 1000w 20amp LiPo charger that cost me like $350 that I use for my R/C trucks, so it has big power. I thought perhaps running off LiPo may provide the power I need, but also give me the ease of just re-charging rather than buying new batteries?
Primary purpose is to have it for my desert shooting trips that are out in the middle of nowhere. I want to be able to shine it out say 50-100yds and be able to see things out there extremely well. I can see needing another light perhaps to see things in a more flood manor up close within 10 yards inside camp?
____I would like to purchase the light from a brick and mortar store. I am located in ______________.
X____I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $25.
____Less than $50.
____Less than $100.
X____Less than $150.
____Less than $300.
____I have no limit.
____I’m flexible, tell me what you gotJ.
____Other, please specify ________
3) Format:
X____I want a flashlight.
____I want a headlamp.
____I want a lantern.
____I want a dive light.
____I want a portable spotlight.
4) Flashlight-specific format/size:
____Keychain size.
____Every day carry small (2-4 inches).
X____Every day carry medium (4-7 inches).
X____Holster carry.
____Big enough to need its own travel caseJ.
____I don’t care.
____I don’t know.
____N/A
5) Emitter/Light source:
X____LED (known for efficiency, longevity, and compactness)
X____Incandescent (known for superior color rendition)
X____HID (known for max output, but often at the expense of size)
____I don't know.
6) Manufacturer:
X____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
X____I would consider getting a light that is pieced together (for example a “host” or flashlight body from one manufacturer, and a “drop-in” emitter from another source). Under the right circumstances, this path can provide more options to the consumer to meet specific needs, and can often be easily upgradeable as technology improves.
7) What battery type do you want to use?
X____I intend to use alkaline batteries (AAA, AA, C, D) (disclaimer, while it does not preclude all choices, these are not recommended for many of today’s most powerful lights)
X____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
X____I intend to use lithium primary batteries (CR123, CR2, Energizer Advanced/Ultimate Lithium AA/AAA)
X____I intend to use rechargeable lithium (li-ion) chemistry. Feel free to specify a size if you know which size you want (14500, RCR123/16340, 17500, 17670, 18650, etc.)
____I want a light with an integrated rechargeable battery. (Note: these choices may be very limited unless you are looking at spotlights)
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to navigate a dark room or read a map (0-10 lumens).
____I want to walk around an unlit rural area (50-150 lumens).
X____I want to illuminate my entire backyard or a campsite (150-300 lumens).
XX____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
___I want ridiculous amounts of lumens (800+ lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
X____50-150 yards/meters (I live in a very rural area/farm with wide open spaces)
____150+ yards (I want maximum throw possible)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
X____30-60 minutes (I have plenty of batteries just ready to be changed)
XX____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Not Important (A “night-stand” light).
X____Very Important (Camping, Backpacking, Car Glove-box).
XX____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't care.
____I don’t know.
12) Switch Type and location (choose all that apply):
____I want a forward clicky (Helpful for momentary activation and signaling).
____I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today’s high end lights).
____I don't care.
X____I don’t know.
____A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
____I want a selector ring.
____I want a strobe mode. (Blinks to show location.)
____I want SOS mode.
____I want a beacon mode.
____I don’t care.
X____I don’t know.
14)Material/Finish/Coating
X____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
X____I don’t care.
____I don’t know.
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____“Hybrid” light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
I'd go for a Zebralight - H600 maybe, that could be used as both headlamp, and a hand held light too.
With your responses on the form, you have a LOT of options available to you.
If you don't have a lot of experience with high end lights, I'd recommend avoiding P60 hosts and modules, as well as anything that requires li-ion rechargeables. Unless you really want to get into it, you'll just be making your life more complicated.
That said, I think a 4xAA or 8xAA light is probably going to be your best bet. I'd suggest you look at a Jetbeam PA40 or a Fenix TK41 or TK45. I'd give the nod first to the PA40, as it is the least expensive and has the simplest user interface. It also comes with a nice holster that you don't have to unbuckle to put on your belt, can be put on a pack if you want, and comes with a lanyard. It'll be lighter too.
If the TK41 is too big, an ld41 seems to fit what you need pretty well.
If I could only have one light, it would be the LD41.
If I could have two lights, I'd want an LD22 and an E40.
The LD22 is a nice floody general use light, the E40 is a throw monster for AAs... good for 500-700 feet of usable light in total darkness, 300 in parking lots.
The LD41 is a little bit of both.
I agree, but from the the list of requirements it sounds like you need 2 separate lights. For example, edc and 300-700 lumens are incompatible requirements.
Normally edc is 1 cell in the 30-100 lumens range.
Maybe a Fenix ld12 combined with a ld41/tk41.
As for batteries AA nimh is usually the simplest option. The new Eneloop 1800 do well in the cold up to minus 20 deg Celsius.
Sent from my GT-I9100M using Tapatalk 2
