I am looking for a headlamp for work. I often find myself in dark basements, attics, and crawlspaces where hands free illumination is essential. I have been using a cheap brand that is causing me a lot of frustration, so it's time for a good quality light. I tried to answer the checklist as good as I can.
==================Flashlight Recommendation Checklist================
This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
Up to $150.
3) Format:
I want a self-contained headlamp or
I want a headlamp with an external pack/power source.
4) Size:
I don’t know/I don't care.
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I want to navigate a dark room or read a map (1-10 lumens).
____I want an indoor "blackout" light (15-50 lumens)
____I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
____Less than 1 yard/meter (reading, other close work)
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
I would prefer a medium mode (80-100 Lumens) that runs for 6-8 hours
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Any size switch will do.
____I want multiple light levels. (Some lights have 5-16 light levels.)
Strongly prefer hidden strobes or no strobes at all
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s higher end flashlights).
15) Water resistance
____IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
16) Storage conditions
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
Light will be stored in a work truck that is parked outside in a northern USA climate
N/A
I await your advice!
Up to $150.
3) Format:
4) Size:
6) Manufacturer:
N/A
