Recommendation for Floating LED Flashlight...
steevireno
I am looking for a good, LED AA-powered, handheld floating flashlight, preferably with a bright colored body. Something around 100 lumens would be ideal.
Any recommendations?
Steve
The only thing that comes to mind is the Eternalight w/lithium AAs.Meets 3 of your criteria but output is no where near 100 lumens.The Eternalight also uses 5MM LEDs so it only provides flood.I am curious to know if there is a flashlight that floats using more current technology. :popcorn:
I would look for a small AA powered dive light and attach a float typically used on boat keychains. Ikelite makes some good and bright colored lights but might not be 100 lumens.
For a lighter weight option, find a nice performing regular 1xAA or 2XAA light that you like and then attach the same boat keychain float.
It's at least an idea.
the floating lights are usually big and bulky 6v lanterns. You could get a plastic D cell flashlight buy an LED drop in from perhaps dorcy and put in AA to D adapters that would probably make it so where it would float. I doubt any metal flashlights float and that is what usually are in the 100 lumen range.
Any light with a lanyard attached to a person that can swim...
Lets throw in some rendunancy here: A light with a lanyard that has a floating foob of some sort... AND is attatched to a person that can swim.
Thanks for all your responses - the purpose of the floating feature is simply in case I (or someone else) dropped it overboard while we were mooring or docked. However the point about using a float on the flashlight seems to be the best choice as there really aren't any good flashlights that float - but plenty that are high lumen and waterproof!
Steve
The Heliotek HTE-1 was designed to float when used with lithium primary cells. Unfortunately, it's black.
I think the Heliotek would be perfect:
-60+ lumens.
-weighs just 6 oz (with lithium batteries)
-beam throws out to 350'
-depth rating of 150'
-6-8 hours of regulated runtime on primary lithiums
-10 year no-nonsense warranty
...and yes, it really floats.:D
It is an amazing light that is very well built.
Check out the front page of the website:
www.heliotekinc.com
The website hasn't been updated in a while so information regarding lumen ratings, throw, etc are a bit outdated. For example they upgraded from a 20 lumen Luxeon to a 60 lumen Cree.
I popped a Terralux TLE-1F bulb into a 6V 'floating lantern'. 50 lumens.
Out throws my '900 lumen' MTE SSC-P7.
Never found out if it floats.
Donut hole at less than 2 meters/7 feet. OK beyond that.
I have tried the TLE-1F in an earlier version of one of these: 4AA 1 LED floating lantern/cool blue etc. (back in 2000 they were 3 lumen, not the current 25.)
http://dorcy.com/products.aspx?p=412498
Donut hole at all distances.
Ended up using a Tektite LPR-3™ bulb 4.5V with 4 NiMH 4.8V.
(The 4 cell LPR-113 was quite dim on 4 NiMH, maybe only as bright as the current stock bulb.)
