recommended flashlight housing
Tekstyle
Does anyone know where i can find a black color flash light that has these dimensions on Dealextreme.com?
outer diameter no larger than 25mm
holds 20mm diameter aspheric lens.
focal distance of lens to the bulb mounting plate (this is referring to the base in which the bulb is epoxied down inside the flashlight) is about 11.2mm apart.
optional: best if it was designed for a 7090 CREE-XRE with star heatsink.
thank you!
