Yep. As was mentioned above, for purely protecting your dark adaptation, red does work best. If you're actually trying to do anything that requires any kind of reasonable visual acuity, then the NVG works best. That's why the military uses it in their low light targeting and detection systems, instead of red.
I thought the NVG were also less affected by this - blinding your helicopter pilot who's flying by NVG is bad, or so I'm told! (Not that I'd know from first hand experience, I'm lucky they let me drive a CAR!
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
That being said, in low light conditions (close to, but not fully scotopic), it only takes me a couple or three minutes for my adaptation to come back after using my NVG light. But, I also turn it on in low and let it ramp up, rather than start it on high. I also use a lower voltage battery, a 2032 in it instead of 2x2016, so it can go lower and doesn't go nearly as high that way.
Thanks - a few minutes would be a reasonable tradeoff in many situations.
I think your intuition about the tasks that have been tested in low light vision not being similar to actual observing conditions is correct. One of the crazy contradictions about this is that most of the people I know in our local club can see the color of different stars even when they're fully scotopically adapted. That leads me to think either that they're not fully scotopically adapted as they think, in order to be able to differentiate different colors of stars, or that they're viewing objects of sufficient magnitude to overcome the scotopic adaptation at just the point where they're seeing the star on their retinae. It would be a small enough area that the total effect wouldn't really be noticeable consciously, or the light wouldn't be intense enough to invoke Whytte's reflex (the reflex where our pupils contract suddenly on exposure to bright light).
That sounds right, because I can definitely vouch for this myself, switching from albireo, a blue and gold double star over to say the veil nebula, the veil is obviously monochrome. Some planetary nebula have a distinct blueish / greenish color. (They mostly glow in OIII light.) These tend to be relatively small as well, not points like stars, but less than an arc minute anyway.
I also agree that very dim red light is essentially useless, except for gross navigation. I'd rather have a dim NVG or white light for that purpose. I've been considering a light that will go ultra low, less than .1 lumen, but I'm still deciding how I want to proceed on this. My wife uses red lights mostly when we're observing, and the NVG photon I gave her for things like reading charts and logging observations. I use mine for pretty much everything. I'm considering getting her one of the new red ZL headlamps that are coming out soon, as she is still pretty traditional about that, and I know that she'd appreciate it, and so would other club members. I still get some negative reactions to my NVG light at club events sometimes.
I know what you mean about club events. I am pretty sure at some clubs you'd get less flack over a one of the new red Olight M20S than you would over your ridiculously faint NVG photon! (I am reasonably sure that with a modicum of dark adaptation, you could probably drive a car at low speeds pretty safely with the Olight! But gee, it's red so it must be OK!)
I highly recommend the ZL headlamps. I will probably buy one of the new H31r's when they come out. I've got the prior model, the h501r, and I really like it and use it heavily. The UI takes some getting used to. It is pretty natural for me to turn it on to low now, but honestly I had to make myself just practice with it for a couple of days until the action became muscle memory. I find it to be extremely useful at my scope, at least when I use any light at all.
For observing though, I'd say that at the eyepiece, you really do want to be as close to scotopic as possible, so red is best for when you're actively working at your scope. My wife is the master at this... she finds stuff with her 10" manual dobsonian that most other people in the club have to use a computer controlled motor drive to find. She's become known for her ability to do that. I am the helper really, fetching food and equipment and stuff like that; I'm simply too ham-handed with the scope to even keep anything centered in the eyepiece... in general though, the NVG meets my needs for both observing and working pretty well. If I was doing the finding and being the primary scope operator, I'd probably want red, but I think NVG would be fine for that too, as long as you didn't get it too bright. My next step is going to be to experiment with using both a red and an NVG light.
Thanks for confirming this, and feel free to post about what you notice about red vs. NVG. I'd be interested in hearing about it. I really appreciate hearing from someone with:
- professional experience on the matter
- actual first hand experience at astronomy
- no real axe to grind
BTW, earlier you mentioned that under dim red light we tend to focus to infinity. Thanks for mentioning that, that explains an issue I didn't understand with my multi-focal contacts. (My soon to be ex-multi-focal contacts.) These things are duds for me - they are AWESOME at near and medium ranges. In daylight, they are slightly blurry at infinity, but they are tolerable, particularly given how good they are everywhere else. And they are comfortable. UNFORTUNATELY, at night, under dim light at infinity, they show double. I can't read street signs, stuff like that. Just not safe to drive while wearing them, but once I reach medium range, I can see OK with them in the dark. However, in my observatory dome, about 10 feet away from me, there's a little red LED on a power supply - and it ALSO was doubled when I looked at it, even though in daylight, at that range it would be in perfect focus with these lenses. But what you said explains this.
Anyway, if your wife can get used to the ZL UI, the little headlamps are just genuinely fantastic in my opinion. (I don't find the UI to be BAD - it is just that it is not natural, you have to press-hold, then double-click to get the lowest light level. In practice this is really no less convenient than just clicking the light on - but it is not what you'll do the first few dozen times you use the light...) I use mine every evening I go out to my observatory. Like I said, I bet I end up with a new one too. It is also pretty comfortable to wear. (OK, my SF saint minimus is better and more comfortable, but it's white light, and it well, cost like it is better too...) I'm not quite sure how many red LED lights I have - I have quite a few. The ZL and an old red SF L1 are the two I grab every night. (The L1 is mostly too bright - it's mainly for critter detection and avoidance!
![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
