Hi All,
I received new MadMAx lite 500(which was impressive improvement over old badboy I've had, producing 1015 lux form 1 meter vs. 335 on BB) and while assemblying that one and sorting out all the mag parts I have accumulated I've found couple mag 2aa reflectors. Which leads to question in the subj. If I cut down mag2aa reflector I guess around 4 5 mm, will it fit Longbow? I am not all that experienced int that kind of work, so all I can do is cut the base with a dremel, and minor filing work, so, will this be suffice, or there is some problem with all that or something I should know about before I start and screw things up?
OBTW, same question for MadMax sandwiches. I want to replace fraen with reflector, don't really like all those squares. Just cut the reflector or drill the wider hole in it?
