Reflector for PM6
tkl
Tx
Is there a reflector I can install in my PM6 led to get more flood?
....so a lesbian, a mexican and a polock walk into a bar.......
taking the reflector out would achieve more flood?
no good, the reflector is connected to the led module.
tkl,
they didn't used to be /ubbthreads/images/graemlins/frown.gif
The SF beam shaper for the "classics" does a nice job of blending the light into more of a flood.
/ubbthreads/images/graemlins/rant.gif /ubbthreads/images/graemlins/banghead.gif
/ubbthreads/images/graemlins/thinking.gif
/ubbthreads/images/graemlins/icon3.gif
The original LED module was independant and you could remove the reflector for a good flood and even put in a bead blasted reflector for a great and even flood beam. The LED and reflector got *integrated* so that there would be no "Adjustable Beam". /ubbthreads/images/graemlins/icon23.gif I say no more so don't ask. /ubbthreads/images/graemlins/icon3.gif
You can cut the reflector off with relative ease as long as you don't cut too deep and cut into the lamp.
Hmmmm. If you can get an old lamp assembly it will screw into the base without a reflector.
Daniel
Don, thanks for the info. Although, I kind of wish you hadn't told me. /ubbthreads/images/graemlins/grin.gif
I haven't screwed anything up with my dremel in a while, so what the hell................... /ubbthreads/images/graemlins/popcorn.gif
The ultimate PM6 Flood reflector is one bead blasted by McGizmo and then converted to a "White Knight" flood using ZOT paint. It is an aerospace coating used for thermal control.
I have several of these treated McFloods and they really are neat... I use them on Mc Moduled PM6's in white and also in red. These modded reflectors put out an even, round, perfectly soft beam. As I recall-the output is 13% greater than a Bead Blasted reflector alone as tested by Doug in TN; And not enough difference to tell from just looking according to Don.
So Bead blast what you've got! Then add flat white krylon if you dare
