Reliability & Performance on a Budget?
jackdaws
I've got about £15 to spend on a keychain light, and £25-30 for an everyday light that I would like to think was good for night-time hiking. Obviously, with less than £50 for two torches, I'll be doing very well indeed to get both reliability and performance, but the former would do as long as they did the job. Both lights would need to operate on rechargeable Li-ion batteries, because buying batteries to throw them away after a week or two is also outside my budget.
Ideally, the keychain light would give 20+ meters beam for more than a few hours whilst providing enough spread of lumens to shed good light a wide driveway. It would be water-resistant, and hard-wearing, and not easily accidentally switch on in a pocket. A strobe might be useful (if ever anyone tried to rob me of my flashlight ;-), but reliability and durability are preferable.
The other light would be about 120-160mm in length, and would have lots of lumens for illuminating a small campsite, but would smoothly zoom out to provide a lengthy beam if neccessary. Again, although a strobe would be useful, the emphasis would be on simplicity, reliability and durability. Certainly, any complicated computer control, involving pressing and/or wiggling triple/quadruple buttons would be more of an intrusion than a feature, and outside my budget.
I've looked at lots of lights on ebay and amazon, but the more I look, the more I become confused. I wonder whether any obvious options spring out? Anyway, for formality, here's the checklist:
- This will be mail-order or Online (location doesn't matter).
2) Budget:
- £50 ($80) for both, if possible.
3) Format:
- a) keychain light
- b) EDL/hiking light
4) Size:
- a) V-Small
- b) Med-Small
5) Emitter/Light source:
- LED
6) Manufacturer:
- Don't care. China, Bangladesh, Pakistan, I don't care. But they must be known for a level of both performance and reliability. A lifetime warranty on an item that would cost more to post back for repair than it's worth would be no use to me, but I want it to work for more than a few weeks.
- Rechargeable cells in both, if possible Li-Ion (I think they offer the biggest amp for your money??)
____I don't care
8) How much genuine out the front (OTF) light do you want/need? - As explained above.
Burst/Turbo mode Category - OK, but not needed.
- Balance between Flood & Throw for both - maximum for each (is that asking too much?)
- 1-25m for keychain
- 3-200m (if possible) for EDL/hiker
- No less than 1.5 hours for keychain
- No less than 4.5 hrs for EDL/hiker
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
- Very Important
- Any size switch will do - but not too sensitive or complicated
- A simple on-off for keychain is okay, but two light levels would be good. Stobe would be okay, but not absolutely neccessary.
- Simple, but easily zoomable, for the EDL hiker. Strobe unnecesary, but SOS would be good, but not neccesary.
14)Material/Finish/Coating
- Tough for both. Probably aluminium.
15) Water resistance
- Water resistant important for both. Submersible would be an added bonus.
16) Storage conditions
- Both will be kept handy wherever I go, but I'm no astronaut.
- Pocket/belt clip on keychain light.
- Wrist/Neck Lanyard on EDL/hiker
For a key-chain light, look at the Olight i3s XP-G2 AAA light. It probably doesn't throw 25m with aplomb, but it's got a 20LM medium, 80LM high and a .5LM moonlight, along with a strobe, so pretty decent spacing in my mind and at about $20 US shipped, they're pretty inexpensive.
Runtime won't be 2 hours, but closer to 50 minutes, however, AAA batteries are small.
That's leaves you about 35 ($55?) pounds for an EDC light, which maybe gets you one of the smaller CR123/AA lights being offered by just about everybody; however, I don't know what you have access to in the UK, for brands and if you go off-site, what type of customs will you'll have to pony up"
I need to google some UK vendors, just to have an idea, lol.
Look at the new versions of the Xeno E03: they offer cool white, warm white and neutral white and they're shipping now with multi-modes and higher 500+ XM-L emitters and are about $33 US shipped.
You can see the lights that I have in my signature, so at least that gives you some fodder for research.
I don't have any FourSevens, NiteCore or ThruNight lights, but look into them, as well.
Chris
Thanks for the quick reply, Chris. It seems that there are four or five really well known and well regarded companies that charge around twice as much as lots of others who claim to be as good as the best, but have yet to gain the respect held for the top few. Would it be a fair reflection to say that (occasional bargains aside) you almost always get what you pay for, or do the well known brands over-charge for what they offer? Also, woulkd you say that there any brands/models that are famous/notorious for a particular quality, such as high power vs. smoothness of colour vs. robustness vs. good battery life?
