FRITZHID
:help:ok, after ripping my stanley HID apart again... for like the 5th time, i've taken some high grade electrical tape, and covered that spill puking flat spot on the edge of the reflector, noted that the lamp has 3 tags on it, 1 says it's a H3 bulb with 8000K yet the other tag, (most of which is in jap/chi writing) has a selection of boxes with 1-12 written in them, and 6 is the box that is checked off. this is making me wonder if this is a 8K or 6K bulb.... since it doesn't seem as Blue as the 8000K HID headlights i've seen around.
for those who have mod's this lamp, does a standard H3 fit? or do i have to mod it 1st?
also, the black tape i covered the flat spot with DOES decrease spill significantly, however, i can't help but feel there is significant lumen loss. anyone know of a drop-in replacement parabolic for this lamp? i'd love to convert that spill into forward focus and tighten up the beam as much as i can. i'd also like to drop the 6-8K down to atleast 5000K if possible, but how will this effect performance? increase of start-up/warmup time? decreased run time?
now... as far as the 3 cute lil LED's they decided to put on, they run at aprox 3v, in series, with a total of 9v going to the array after the on-board control circuits, prior to that full 12v are supplied to the PCB itself. lumens are fairly low, i'd like to increase them as high as i can using 5mm leds, i'm confident in removal/rewiring the PCB as needed to power what ever anyone suggests, cooling however is where the main issue would lie.
any suggestions to this point in my project?:thanks:
