jtivat
Review of new 3volt rechargeable\'s from JonSidneyB
First these cells are a bit wider than a regular 123 as one got stuck in my Surefire L1 and was a tight fit in my A2. The bottom or negative side seems to have more tape or whatever it is they use to wrap them in. I needed to use some foil to get them to work in an old style twisty Arc LS. I first did a runtime test in the A2 but could not get any light out of it? Not sure what the problem is there? Next I did a runtime test in an Arc LS with a good binned LS III the Arc is using it's stock circuitry. The light just shut off after 40 minutes constant on. I think this was some kind of internal protection as the light and battery where very warm. I am not sure though as it has been over ten minutes and I am still not getting anything out of the battery. I am doing another test with the second battery right now in a FF with a BB500 I will report back shortly with the results.
