[Review] - Ruike - Hussar M121-TZ + P875-SZ + P881-W - by Lock
lock
Italia
Hello everyone, today we will see three new Ruike knives:
  • Ruike P875-SZ
  • ​Ruike P881-W
  • Ruike Hussar M121-TZ
Content and Packaging
The three Ruike knives arrive in a small cardboard box, with a user manual, the warranty card and a small advertising leaflet of the company inside.
A thick transparent plastic bag protects the knives during transport
P875-SZ: Product description
The Ruike P875-SZ is a knife made almost exclusively of stainless steel, with a simple but elegant design. Direct successor of the M875 from which it differs essentially for the steel of the blade (14C28N) and for the handle in 420, it has an engraving on the handle with a particular honeysuckle motif (plant whose flowers are traditionally considered a symbol wishes) which, in addition to an aesthetic factor, contributes to improving grip and always maintaining a firm grip. There is also a small G10 and Carbon insert on the handle, ... a real gem!
The P875 is equipped with the safety lock patented by Ruike "Beta Plus" (in addition to the classic frame Lock) which prevents accidental closing of the blade.
Included, already installed on the knife is a removable belt clip.
P875-SZ: Technical specifications
• Overall Length: 208 mm / 8.19"
• Blade Length: 89 mm / 3.50"
• Blade Thickness: 3.5 mm / 0.14"
• Weight: 140 g / 4.94 oz
• Blade Material: 14C28N stainless steel (58~60 HRC)
• Finish: Bead blast
• Handle Material: 420 stainless steel
• Locking: Frame lock w/ "Beta Plus" safety system
P881-W: Product description
Developed on the basis of the classic Karambit knives, the P881 was designed and conceived purely for tactical uses, for the outdoors and for rescue operations
This knife is equipped with a rear safety ring and an ergonomic G10 handle that offers excellent grip and a comfortable reverse grip. Small and compact, it is easy to transport and hide. The blade lock is entrusted to the classic liner lock.
Sandvik 14C28N stainless steel with cryogenic treatment
Sandvik 14C28N is a martensitic chromium stainless steel with an optimized chemistry used for high quality professional knives that require high sharpening and corrosion resistance requirements. The 14C28N of this knife is tempered by RUIKE and subjected to cryogenic treatment to guarantee a hardness of 58 ~ 60 HRC.
G10 handle
The handles of the RUIKE knives are a mixture of fiberglass and resin and guarantee high resistance to stress, scratches and abrasions.
Ball bearing washer
The integrated lubricated balls are made of high carbon steel for excellent hardness and wear resistance.
P881-W: Technical specifications
• Overall Length: 202 mm / 7.95"
• Weight: 134 g / 4.73 oz
• Blade Length: 75.5 mm / 2.97"
• Finish: Stonewash
• Handle Material: G10 w/ 420 stainless steel liner
• Opening: (Manual) Flipper
• Locking: Liner lock
Hussar M121-TZ: Product description
The Hussar M121-TZ was born as a direct successor to the M121 from which it differs for the steel of the blade (S35VN), for a titanium handle and for the presence of the new "Beta Plus" blade block
S35VN stainless steel with cryogenic treatment
The S35VN steel, produced in the United States, is one of the most popular high-end stainless steels. With a uniform distribution of the carbide, it offers excellent qualities of hardness and strength of the edges and good resistance to corrosion. The S35VN blade is further treated by RUIKE with a cryogenic treatment to guarantee a hardness of 58 ~ 60 HRC.
Titanium handle TC4
The use of titanium as the main material of the handle helps to reduce weight, avoiding any problem due to corrosion and ensuring high reliability.
"Beta Plus" safety lock
Ruike's "Beta Plus" is a patented and proprietary Technology. This system avoids accidental blade closure, always ensuring maximum safety when using the knife.
Hussar M121-TZ: Technical specifications
• Overall Length: 215 mm / 8.46"
• Weight: 110 g / 3.88 oz
• Blade Length: 92 mm / 3.62"
• Blade Material: S35VN stainless steel (58~60 HRC)
• Handle Material: TC4 titanium
• Bearing / washer: Ball bearing washer
Conclusions
Three fantastic knives !!! These Ruike are really well made.
I like them a lot not only from the aesthetic point of view but above all for the construction quality and the materials used. There is no type of "play" between the fixed and mobile mechanical parts.
Here is a brief summary with some personal considerations:
Hussar M121-TZ: light and very handy, sharp as a razor, it holds well in the hand. It has the Beta Plus auxiliary blade lock in addition to the classic frame lock. The flip opening is very very smooth. Beautiful clip of electric blue color.
P875-SZ: blade slightly wider than the Hussar but with the same cutting capacity. The knife comes very sharp. The carbon insert on the cheek and the beautiful design on the handle are the icing on the cake and give an extra touch of class to this model. The P875-SZ also features the "Beta Plus" blade locking system in addition to the Frame Lock
P881-W: Knife a bit heavier than the other two. Abundant thicknesses but, despite this, fairly low weight. Ergonomic G10 handle, with a particular shape that allows a firm and safe reverse grip. The tactical tail ring can be used, for example, as a glassbreaker and in emergency situations. The blade lock is entrusted only to the Liner Lock.
Given the impossibility of leaving the house, I could not test the knives in the field as I usually do.
So you are wondering if they cut ... well, I guarantee you that they are razor sharp, especially the Hussar M121-TZ and the P875-SZ.
For now I can only say that I am pleasantly impressed by these three models.
Thanks for reading !!! XD
Thanks for the review and amzing photos! I only own the poorman's version of the Hussar with G10 scales, but I was really impressed by the overall fit&finish and the really cheap price. It's actually one of my favorite knives as of late with its unique bladeshape/grind and smooth opening action. Now that I see that gorgeous P875 I'm sure my Hussar won't be alone much longer...gotta check prices real quick :grin2:
