XTAR MAGNEMITE H3R – is a typical shape of an angle flashlight that we can successfully use as a headlamp. Here summary some reviews:
00:08: unboxing of XTAR H3R
01:21: magnetic charging test
02:01: light function test
02:54: outdoor light test
03:49: indoor light test
04:14: test when wearing head strap
04:51: helmet clip test
05:46: bracket test
06:28: test when wearing helmet
06:50: waterproof test
07:16: magnet strength test
With magnetic charging, just a lightly touch leads you to a new shining world.
• Good runtime
• Instant access to Moon mode and Turbo mode
• Good white tint
• Strong Helmet Clip
• Side switch is easy to activate
• Fast 1A USB charging
• Consider lightweight for its size
Specifications:
Led : Cree XP-L V6
6 different modes
Max intensity : 5630cd
Max output : 1000 lumen
Max runtime : 18 days
Max beam distance : 150 meters
Waterproof : IPX-7
Impact resistant : 1.5 meters
Battery : 1×18650 / 2×16430 / 2xCR123A
Low voltage protection
Overheat protection
Dimension : 106.4mm x 21.9mm x 26.7mm
Weight : 55g
*Magnetic charging only for 18650
It is non-proprietary battery support. Any 18650 Li-ion battery, protected or unprotected, button-top or flat-top can be used.
^^ However, I do not recommend using battery with proprietary positive and negative contact point at the same side as the contact spring might risk creating a short.
Turn the torch on / off with a single click. The flashlight switches on with the memory of the last mode (even TURBO) – unless you change the link, then it will start in high mode.
Change the modes by holding down the button; they operate in the loop from the lowest to the highest. TURBO is activated by a fast double click (on the flashlight).
Hidden modes:
- quick 3 clicks activate SOS
- when the torch is off we hold the button – to enable / disable the button lock against accidental switching on (when the lock is on and the button is pressed, the flashlight will turn on in the moon for a moment, when the button is released, the torch will go out)
- when the torch is off, two quick clicks activate TURBO
- when the flashlight is off, hold the button for a moment – it will turn on in the moon mode.
Summary:
XTAR MAGNEMITE H3R is a headlamp designed mainly for people who expect a good range from a flashlight that they can wear on their head. Good workmanship, magnetic charging and easy-to-use controller, plus good equipment make H3R a really interesting proposition.
05:46: bracket test
• Good runtime
• Good white tint
Specifications:
Led : Cree XP-L V6
6 different modes
Waterproof : IPX-7
Overheat protection
Weight : 55g
Hidden modes:
Summary:
