whc
UPDATE 8/3-07: After finding the first REX2.1 I received was a defective ond and was not living up to the specifications provided, Kai at Kaidomain.com send me a new one that just received today (very good service) and let me just say WOW . So not it is time to update the review now when I have received a fully working REX2.1. Did not have time to edit the pictures I took, so the new pictures does not contain any writings on them.
For all of you who are holding back of getting one as a result of the bad output of the first one I got, I can now say that Kai @ Kaidomain will be QC every REX2.1 before shipping, so new buyers should not be worried of getting a defective one, it was as far as I can tell rexlight that faild on QC thir products.
Now to the review, anjoy .
Just received the brand new Rexlight REX2.1 (updated version of REX2.0). Got it directly from Kai @ Kaidomain, you can also buy it at Lighthound: http://www.lighthound.com/index.asp?PageAction=VIEWPROD&ProdID=2893
This review will focusing on what is new in the REX2.1 compared to REX2.0. If you want more details on REX2.0 I can point you to this review: http://www.candlepowerforums.com/vb/showthread.php?t=161789&highlight=rexlight
Updates in REX2.1 compared to REX2.0:
New UI (User Interface) with only 2sec memory function, plus tree new light modes (Daily/Tactic/Advance), I have made a video of the UI in action here: http://www.youtube.com/watch?v=0ZrazfJRGSM
The glass lens I thicker and has a better AR-Coating.
New LED&Reflector module (kind of a drop in module).
More soft rubber on/off switch cover makes it easier to turn it on/off.
Reflector is more textured, makes a not quite as good beam as REX2.0 IMO.
The PWM is now completely Flicker-free on low (I can't notice any flicker with my bare eye).
Only one o-ring in each end = easier to change battery compared to REX2.0.
LED/PCB now glued to the heatsink.
Low battery warning on Li-Ion (works very well).
That was all I could think of right now, here is what I find good and bad:
The bad - <-Updated!
- "Only" one o-ring in each end (REX2.0 had two).
- New reflector has noticeable dark halo surrounding the hotspot (the old REX2.0 was much better).
- The new switch rubber cover, makes it harder to make the flashlight stand on its tail (better on the new one I got).
The good + <-Updated!
+ Very bright, brightest one I got.
+ Switch much easier to press with new rubber cover.
+ Lens is thicker and much better AR-coating.
+ The UI is MUCH better than the REX2.0, like the "blink" when a mode has bean on for longer than 2 sec (indicating that the mode will be used next time turned on).
+ Like the new LED&Reflector module, like a drop in (reflector is tighten to the LED module).
+ The one o-ring makes it much easier to change battery.
+ Flicker free, no noticeable flicker detected with the bare eye on low.
+ Low battery indicator on Li-Ion (blinks when battery is low).
+ Good looking HAIII.
Now to some pictures for you to enjoy .
Left: NEW REX2.1, Right: OLD REX2.1 <-Updated!
The REX2.0 is NOT the original PCB/LED, my LED burned, so changed the whole PCB/LED module.
Now to the beamshot department, enjoy .
Left: REX2.1 (NEW) Alkaline on High, Right: REX2.1 (OLD) Alkaline on High <-Updated!
Left: REX2.1 (NEW) Alkaline on High, Right: REX2.1 (OLD) Alkaline on High, 2-stops underexposed <-Updated!
Left: REX2.1 (NEW) Ni-Mh on High, Right: REX2.1 (OLD) Ni-Mh on High <-Updated!
Left: REX2.1 (NEW) Ni-Mh on High, Right: REX2.1 (OLD) Ni-Mh on High, 2-stops underexpose <-Updated!
Left: REX2.1 (NEW) Li-Ion on High, Right: REX2.1 (OLD) Li-Ion on High <-Updated!
Left: REX2.1 (NEW) Li-Ion on High, Right: REX2.1 (OLD) Li-Ion on High, 2-stops underexpose <-Updated!
Left: REX2.1 (NEW) Li-Ion on High, Right: REX2.0 Li-Ion on High <-Updated!
Left: REX2.1 (NEW) Li-Ion on High, Right: REX2.0 Li-Ion on High, 2-stops underexpose <-Updated!
Left: REX2.1 (NEW) Li-Ion on High, Right: L1T with Rebel Li-Ion on High <-Updated!
Left: REX2.1 (NEW) Li-Ion on High, Right: L1T with Rebel Li-Ion on High, 2-stops underexpose <-Updated!
Left: REX2.1 (NEW) Alkaline on High, Right: Fenix L1D-CE Alkaline on Turbo <-Updated!
Left: REX2.1 (NEW) Alkaline on High, Right: Fenix L1D-CE Alkaline on Turbo, 2-stops underexpose <-Updated!
Left: REX2.1 (NEW) Ni-MH on High, Right: Fenix L1D-CE Ni-MH on Turbo <-Updated!
Left: REX2.1 (NEW) Ni-MH on High, Right: Fenix L1D-CE Ni-MH on Turbo, 2-stops underexpose <-Updated!
Left: REX2.1 (NEW) Ni-Mh on Medium, Right: L1D-CE OP Ni-Mh on Medium <-Updated!
Left: REX2.1 (NEW) Ni-Mh on Medium, Right: L1D-CE OP Ni-Mh on Medium, 2-stops underexposed <-Updated!
Left: REX2.1 (NEW) Ni-Mh on Low, Right: L1D-CE OP Ni-Mh on Low <-Updated!
Left: REX2.1 (NEW) Ni-Mh on Low, Right: L1D-CE OP Ni-Mh on Low, 2-stops underexposed <-Updated!
Left: REX2.1 (NEW) Li-Ion on High, Right: Fenix L1D-CE Li-Ion on Turbo <-Updated!
Left: REX2.1 (NEW) Li-Ion on High, Right: Fenix L1D-CE Li-Ion on Turbo, 2-stops underexpose <-Updated!
Now to the Lux readings department...:naughty:...
Here is some Lux reading of Overall Output:
Rexlight REX2.1 (NEW): <-Updated!
1xAA Ni-Mh on high: 4660 Lux
1xAA Ni-Mh on medium: 1819 Lux
1xAA Ni-Mh on low: 179 Lux
1xAA Alkaline on high: 4130 Lux
1xAA Alkaline on medium: 1771 Lux
1xAA Alkaline on low: 180 Lux
1x14500 Li-ion on high: 9150 Lux
1x14500 Li-ion on medium: 3710 Lux
1x14500 Li-ion on low: 601 Lux
Rexlight REX2.1 (OLD):
1xAA Ni-Mh on high: 2810 Lux
1xAA Ni-Mh on medium: 910 Lux
1xAA Ni-Mh on low: 94 Lux
1xAA Alkaline on high: 2670 Lux
1xAA Alkaline on medium: 843 Lux
1xAA Alkaline on low: 94 Lux
1x14500 Li-ion on high: 7310 Lux
1x14500 Li-ion on medium: 3060 Lux
1x14500 Li-ion on low: 470 Lux
Amilite T5:
1xRCR123A 3.0v on high: 8340 Lux
1xRCR123A 3.7v on high: 10910 Lux
Dereelight DR-CL1H:
1x18650 3.7v SSC P4 on high: 7300 Lux
1x18650 3.7v SSC P4 on low: 2190 Lux
2xRCR123A 3.7v SSC P4 on high: 7740 Lux
2xRCR123A 3.7v SSC P4 on low: 3450 Lux
1x18650 3.7v Cree XR-E on high: 7340 Lux
1x18650 3.7v Cree XR-E on low: 2560 Lux
2xRCR123A 3.7v Cree XR-E on high: 7290 Lux
2xRCR123A 3.7v Cree XR-E on low: 2840 Lux
Fenix L1D-CE:
1xAA Ni-Mh on turbo: 3990 Lux
1xAA Ni-Mh on high: 3770 Lux
1xAA Ni-Mh on medium: 1910 Lux
1xAA Ni-Mh on low: 430 Lux
1xAA Ni-Mh OP on turbo: 4410 Lux
1xAA Ni-Mh OP on high: 4030 Lux
1xAA Ni-Mh OP on medium: 2060 Lux
1xAA Ni-Mh OP on low: 460 Lux
1xAA Alkaline OP on turbo: 4400 Lux
1xAA Alkaline OP on high: 3650 Lux
1xAA Alkaline OP on medium: 1922 Lux
1xAA Alkaline OP on low: 420 Lux
1x14500 Li-ion on turbo: 8240 Lux
1x14500 Li-ion OP on turbo: 8390 Lux
Led-Lenser Hokus Fokus:
3xAAA Ni-Mh: 4850 Lux
Lumapower M1:
1x18650 XR-E OP on high: 8140 Lux
1x18650 XR-E OP on low: 1640 Lux
2xRCR123A 3.7v XR-E OP: 8950 Lux
1x18650 SSC P4 OP: 5540 Lux
2xRCR123A 3.7v SSC P4 OP: 8230 Lux
Lumapower Tactical M1:
1x18650 3.7v OP on high: 7770 Lux
1x18650 3.7v SM on high: 8140 Lux
2xRCR123A 3.7v OP on high: 8130 Lux
2xRCR123A 3.7v SM on high: 8250 Lux
Lumapower LP-Mini:
1xRCR123A 3.7v OP: 7810 Lux
Lumapower M3:
1xAA Ni-Mh on high: 3640 Lux
1xAA Ni-Mh on medium: 1270 Lux
1xAA Ni-Mh on low: 40 Lux
2xAA Ni-Mh on high: 4300 Lux
2xAA Ni-Mh on medium: 1310 Lux
2xAA Ni-Mh on low: 350 Lux
1x14500 Li-Ion on high: 5880 Lux
1x14500 Li-Ion on medium: 3020 Lux
1x14500 Li-Ion on low: 690 Lux
1xRCR123A 3.7v on high: 4390 Lux
1xRCR123A 3.7v on medium: 2940 Lux
1xRCR123A 3.7v on low: 680 Lux
Nuwai X-3:
2xAA Ni-Mh: 3020 Lux
Ultrafire WF-500L:
2x18650 3.7v: 4660 Lux
Rexlight REX2.0:
1xAA Ni-Mh on high: 3810 Lux
1xAA Ni-Mh on medium: 810 Lux
1xAA Ni-Mh on low: 210 Lux
1xAA Alkaline on high: 4420 Lux
1xAA Alkaline on medium: 980 Lux
1xAA Alkaline on low: 252 Lux
1x14500 Li-Ion on high: 5550 Lux
1x14500 Li-Ion on medium: 1570 Lux
1x14500 Li-Ion on low: 570 Lux
Waion VB-16 4th gen.:
1x18650 3.7v on high: 8970 Lux
1x18650 3.7v on low: 48 Lux
2x18650 3.7v on high: 9150 Lux
2x18650 3.7v on low: 55 Lux
2xRCR123A 3.7v on high: 9090 Lux
2xRCR123A 3.7v on low: 53 Lux
Here is some Lux reading at 1m in Throw:
1xAA Ni-Mh on high: 1463 Lux
1xAA Ni-Mh on medium: 594 Lux
1xAA Ni-Mh on low: 61 Lux
1xAA Alkaline on high: 1193 Lux
1xAA Alkaline on medium: 582 Lux
1xAA Alkaline on low: 61 Lux
1x14500 Li-ion on high: 2760 Lux
1x14500 Li-ion on medium: 1154 Lux
1x14500 Li-ion on low: 192 Lux
1xAA Ni-Mh on high: 629 Lux
1xAA Ni-Mh on medium: 256 Lux
1xAA Ni-Mh on low: 27 Lux
1xAA Alkaline on high: 776 Lux
1xAA Alkaline on medium: 250 Lux
1xAA Alkaline on low: 30 Lux
1x14500 Li-ion on high: 1850 Lux
1x14500 Li-ion on medium: 800 Lux
1x14500 Li-ion on low: 118 Lux
Amilite T5:
1xRCR123A 3.0v on high: 2520 Lux
1xRCR123A 3.7v on high: 3260 Lux
Dereelight DR-CL1H:
1x18650 3.7v SSC P4 on high: 2430 Lux
1x18650 3.7v SSC P4 on low: 1110 Lux
2xRCR123A 3.7v SSC P4 on high: 2540 Lux
2xRCR123A 3.7v SSC P4 on low: 1550 Lux
1x18650 3.7v Cree XR-E on high: 3290 Lux
1x18650 3.7v Cree XR-E on low: 1160 Lux
2xRCR123A 3.7v Cree XR-E on high: 3410 Lux
2xRCR123A 3.7v Cree XR-E on low: 1380 Lux
Fenix L1D CE:
1xAA Ni-Mh on turbo: 1460 Lux
1xAA Ni-Mh OP on turbo: 1510 Lux
1xAA Ni-Mh OP on high: 1410 Lux
1xAA Ni-Mh OP on medium: 730 Lux
1xAA Ni-Mh OP on low: 170 Lux
1xAA Alkaline OP on turbo: 1374 Lux
1xAA Alkaline OP on high: 1196 Lux
1xAA Alkaline OP on medium: 690 Lux
1xAA Alkaline OP on low: 124 Lux
1x14500 Li-ion on turbo: 3150 Lux
1x14500 Li-ion OP on turbo: 2820 Lux
3xAAA Ni-Mh: 4460 Lux
Lumapower M1:
1x18650 XR-E OP on high: 4820 Lux
2xRCR123A 3.7v XR-E OP: 5500 Lux
1x18650 3.7v OP on high: 4940 Lux
1x18650 3.7v SM on high: 7150 Lux
2xRCR123A 3.7v OP on high: 5070 Lux
2xRCR123A 3.7v SM on high: 7390 Lux
Lumapower M3:
1xAA Ni-Mh on high: 1240 Lux
2xAA Ni-Mh on high: 1530 Lux
1x14500 Li-Ion on high: 1980 Lux
1xRCR123A 3.7v on high: 1550 Lux
Lumapower Lp-Mini:
1xRCR123A 3.7v OP: 4700 Lux
Nuwai X-3:
2xAA Ni-Mh: 1340 Lux
Ultrafire WF-500L:
2x18650 3.7v: 4710 Lux
Rexlight REX2.0:
1xAA Ni-Mh on high: 840 Lux
1xAA Ni-Mh on medium: 210 Lux
1xAA Ni-Mh on low: 60 Lux
1xAA Alkaline on high: 1087 Lux
1xAA Alkaline on medium: 256 Lux
1xAA Alkaline on low: 83 Lux
1x14500 Li-Ion on high: 1460 Lux
1x14500 Li-Ion on medium: 460 Lux
1x14500 Li-Ion on low: 160 Lux
1x18650 3.7v on high: 4540 Lux
2x18650 3.7v on high: 4560 Lux
2xRCR123A 3.7v on high: 5230 Lux
First runtime done:
1x AW Protected 14500 Li-Ion: 1hour 12min 40sec, until the protection circuit kicked in (the flashlight flashes).
1x Ni-Mh 2500Mah: 1hour 45min -> 50% Stopped the test after 2hours still with decent light (and many hours forward).
Some throw shot for ya all .
Rexlight REX2.1 (NEW) Li-Ion on High <-Updated!
Rexlight REX2.0 Li-Ion on High <-Updated!
Fenix L1D-CE OP Li-Ion on Turbo <-Updated!
Fenix L1T Rebel Li-Ion on High <-Updated!
Rexlight REX2.1 (NEW) Alkaline on High <-Updated!
Rexlight REX2.0 Alkaline on High <-Updated!
Fenix L1D-CE OP Alkaline on Turbo <-Updated!
Rexlight REX2.1 (NEW) Ni-Mh on High <-Updated!
Rexlight REX2.0 Ni-Mh on High <-Updated!
Fenix L1D-CE OP Ni-Mh on Turbo <-Updated!
Amilite T5:
Dereelight DR-CL1H:
Fenix L1D-CE:
Lumapower M1:
Lumapower LP-Mini:
Lumapower M3:
Nuwai X-3:
Ultrafire WF-500L:
Rexlight REX2.0:
Amilite T5:
Dereelight DR-CL1H:
Fenix L1D CE:
Lumapower M1:
Lumapower M3:
Lumapower Lp-Mini:
Nuwai X-3:
Ultrafire WF-500L:
Rexlight REX2.0:
First runtime done:
