RF noise
chiphead
Hutto,TX
While doing some AM/Shortwave DXing the other night, I noticed that my INOVA 24/7 was putting out RF noise! I'm betting that some of the inductors (transformers, coils, etc) in these switching power supplies aren't that well shielded.
chiphead
---------------------- /ubbthreads/images/graemlins/ooo.gif
PeLu:
What's the latest hottest caving light these days??
Thanks /ubbthreads/images/graemlins/wink2.gif
I have had the same type of RFI when using my HF ham rig.
Thats why I now use a directly driven light.
Interesting - Now that I think of it - all the "electronic" lights should have to go for Part 15 testing, and have to be labeled.......
(BIG can of worms I just opened)
Ah... I had wondered if the red leds in the 24/7 were direct drive or not. And the answer is, no they are not. There is RF hash generated even with the red leds.
[ QUOTE ]
[/ QUOTE ]
Surefire does this - FCC/CE marks on the bezel.
Guys!
Some clarification here, my Inova 24/7 emmits this on the low beam. On the high beam end the frequency of the noise seems to double. No big deal mind you, just surprised.
chiphead
I've got some caving plans in the works, but for right now I'm going to use my Inova 24/7 with its headband attachment.
chiphead /ubbthreads/images/graemlins/smile.gif
[ QUOTE ]
sotto said:
PeLu:
[/ QUOTE ]
A Petzl Aceto.
Two FCC classes, A and B (and technically a flashlight is exempt from both). A class A device can actually be pretty noisy. I don't remember the exact spread, but let me put it this way: You can generally achieve Class A with just good engineering practices, nothing exotic. Class B compliance has to be designed in from the outset, good engineering practices are nowhere near good enough. In some class B laptops I have worked on, I have been surprised at the number of shields and ground leads used internally to bottle up emissions. (Laptops sold in the USA must be Class B, desktops can be A or B depending upon the intended market).
FCC complaince does not guarantee RF silence, it places a limit on it, and the limit for class A is a lot higher than the limit for class B. I know from my trips out to the Test Range, that test eqipment had not trouble picking up the internal clocks at 10 meters with an omni-directional antenna, yet we were still about 3db inside the FCC class A limit on radiated emissions. My other experience is that most product that says it is class A, isn't (and that is from operating them on the test range). Class A is self certifying, and lets just say a lot of vendors take a very liberal view of the FCC regulations. Class B requires conformance, an conforming test report that the test range certifies, and the FCC issuing you an ID for the product. If your Class B product subsequently fails inspect, both you , and the Test range get fined. Suffices to say that the test range will insist that meet class B by a comfortable margin, so that any corners you may subsequently cut in manufacturing will still product a device that the FCC isn't going to fine anyone over.
[ QUOTE ]
[/ QUOTE ]
So would a resistored LED flashlight inherently meet class B, or would you expect the on/ off switch to be a factor ?
If it was battery powered, however diodes are inherently non-linear devices, so if you feed it with something other than DC, it can be a significant source of noise. In fact diode noise generators are common. in regulated lights, the DC to DC power supply is a significant noise source.
However this is largely academic. Flashlights are intended as mobile devices, so are exempt from the conducted/radiated emissions standards.
