Here's my parts list so far: <font class="small">Code:</font><hr /><pre>
6 LXHL-MM1D @ 13.82 = $82.92
6 LXHL-MRRD @ 13.82 = $82.92
6 LXHL-MD1D @ 13.82 = $82.92 + shipping
DigiKey
1 EPS265-ND 12V 2.5A 30W desktop power supply = $46.80
3 PP1045SB-ND 10K slider pot @ 2.84 = $ 8.52
3 MPSA63-ND PNP Darlington @ 0.26 = .78
5 BC604YCT-ND 604ohm .4W 1% @ .19 = .95
12 A9049-ND 6-6 jack @ .75 = $ 9.00
6 H2661-07-ND 6-pin cable @ 3.08 = $18.48
1 EG2429-ND 4PDT switch = $13.62
3 ALSR5F01.0-ND 1ohm 5W @ 1.30 = 3.90
3 MSG13-ND 1K ohm pot @ 1.59 = 4.77
</pre><hr />
I actually need two more of the 6-pin RJ-12 jacks, but miscounted when I placed that order. Sigh. Waiting for some other needs to turn up so I can place a large enough order to avoid the handling charge for small orders...
So far I've spent almost $400.00 on this project; could have bought a Colour Kinetics professional lightwasher for this price. Oh well.
I have a sheet of aluminum that I'll be carving up to mount the Luxeons. A cluster of 3 per sheet, with two 6-pin jacks on each. The clusters will be wired for daisy-chaining - R+, G+, and B+ coming in, going through the stars, and then out the 2nd connector. I'll wire a shorting plug for the end of each chain, that wraps the output R+ to the R-, etc. and all of the - lines will just run straight thru back to the power supply.
E.g.<font class="small">Code:</font><hr /><pre>
+V --> R+ --> Luxeon --> R+ --> Luxeon --+
GND <-- R- <-- ------ <-- R- <-- ------ --+
</pre><hr />
The 3 10K sliders will be used for manual control of the individual colors. The 4PDT switch will toggle the color drivers between the slider input and the CKSauce controller. The output of the switch will drive the 3 Darlington transistors to feed current down the chains. The 1K trimmer pots are for fine-tuning the drive current for the Darlingtons. The 5W 1ohm resistors are for the emitter side of the transistors, they'll have to handle all of the current in the system.
(Hm - how come the "code" UBB directive doesn't switch to a fixed-width font automatically??)
