I'm wondering if anyone else has done the mod that I jsut did.
I'm sure we are all familiar with the RGBW MCE and the common driver that is made for it.
I got mine from outdoor Intl.
And I'm sure most of you are familiar with the RGBW XML.
And it has been discussed that there is not matching driver for the XML and we are stuck using the MCE driver that under drives it.
Reference, The MCE is rated for 700ma, and the XML version is 1000.
I'm a technician by trade so I had a hunch . . .
I looked up the data sheet of the regulators that driver uses and noticed that they are generic adjustable regulators unlike the 7135's that are commonly used and can actually handle 3 or 5 amps or something like that, I forget off the top of my head.
When I got the driver I noticed there was indeed a bias resistor on each regulator to set it's output.
So what I did what figured out what resistance value I needed to set the driver to correctly run the XML.
The stock value is 911ohms and that gave me about 700-800ma tested between the driver and the LED.
I determined a required value of about 500ohm. I was able to find a 470ohm resistor of the correct size in my scrap.
I removed the stock resistor and installed the 470 and measured 1.3a drive to the LED.
Eureka!
I left the colour output values alone as I'm not concerned with them, but was able to mod this driver to run the white emitter into a slight overdrive sweetspot.
Doing a search on this forum I have not found any talk of this sort of mod to get the most out of the RGBW XML.
I figured it would be a good idea to share my findings.
I'm going to torture test setup soon.
Pic or it didn't happen:
Eureka!
