ernsanada
- Joined
- Apr 29, 2004
- Messages
- 2,962
I just received the Romisen RC-P3 2AA from Deal Extreme.
From ordering to receiving the light it took 11 days.
Shipping took 8 days.
Cost $17.53 +.01 cents (shipping)
Came only with a lanyard.
Made by Romisen. This is the first light I have purchased from Romisen.
Uses side switch reverse clickie. Finally a different switch location.
Aluminum reflector and glass lens.
Type II Anodize is very good.
Fit is very good.
Uses Cree.
The beam seems off center. Has a ring around the corona.
The light is long due to the use of the side switch.
I am using Energizer Rechargeable Nimh AA 2500mAh. The batteries fit tight.
I like 2AA lights. They make good canidates to use at work.
Has a clear plastic cover to protect the reflector from shorting out the Cree.
The Cree Module comes out with no effort.
No rear clickie!
Uses a side switch reverse clickie.
Rear view of the aluminum reflector.
Rear view of the Cree Module.
Front view of the battery tube. The side switch is located here. This is where the Cree module makes contact.
Inside view of the rear tailcap.
O-rings did not come lubed.
Size comparison.
Left, Romisen RC-P3 2AA. Right, Ultrafire WF-606A1 2AA
I also took lux readings of both lights from above. These are the lux readings I got. I am using a Meterman LM631 Light Meter measured at 1 meter. I waited 2 minutes before taking the readings. I am using Energizer Rechargeable Nimh AA 2500mAh Nimh AA's which were fully charged.
Romisen RC-P3 2AA - 1960 lux @ 1 meter
Ultrafire WF-606A1 2AA - 2260 lux @ 1 meter
Cleaned contacts with Deoxit.
Romisen RC-P3 2AA - 2090 lux @ 1 meter
Romisen RC-P3 2AA @ 87"
Ultrafire WF-606A1 2AA @ 87"
Romisen RC-P3 2AA @ 87" Stepped down exposure
Ultrafire WF-606A1 2AA @ 87" Stepped down exposure
Left, Romisen RC-P3 2AA. Right, Ultrafire WF-606A1 2AA @ 87"
Left, Romisen RC-P3 2AA. Right, Ultrafire WF-606A1 2AA @ 87" Stepped down exposure
In this picture you can see the beam of the Romisen RC-P3 2AA being off center. The ring around the corona is off center.
This is the only drawback I could find about this light.
The ring doesn't bother me.
I think this is a good deal for the price of $17.54.
Fit is very good.
Uses Cree.
No rear clickie!
Size comparison.
