ROP conversion to LED?
PuZo
I have a 2D ROP and was wondering if making it LED would produce better output?
Benson
I assume you're using the Hi bulb...
XM-L at rated spec (3A) will be slightly dimmer, but you can overdrive it to match or exceed with good heatsinking.
SST-50 at spec (5A) is basically equal to ROP-hi, but a direct-drive with 4 D cells would go well past -- lots of heat to deal with though.
SST-90 is the only one that will really be a big improvement at spec (9A), but again, lots of heat.
aoyiteled
Personal opinion: eyes have a detailed check, in accordance with the LED lamp features to select, regardless of power, or color, or luminous flux is the need to consider!
