RRT-0 reflector replacement help
nvrdark
Carmel, IN
I got an OP reflector for my new RRT-0 but can't get to it. I think I need to remove the SS bezel but can't get it off and don't want to grab it with a regular pair of pliers. I have tried the sears rubber strap do hickies but they are to wide. I had the same problem with Robo grips with the protective covers.
Anyone done this without ruining the bezel.
Thanks
Some of the standard ways are to press it into the sole of a shoe or old mouse pad and twist.
I used needle nose pliers on mine. It's steel, it won't scratch very easily. Go for it. Just place them, then squeeze the handles apart to keep them in the grooves. It twists off without much effort, but you have to break it loose.
I put a crenellated HDS/Aleph 2 bezel on mine and dropped in an old Cree XR-E optic that improved the beam - less ringy and smoother spill cut-off. I put a Q3-5A in it too and it's my current EDC.
<edit>
The long nose pliers on the inside of the bezel worked great. Thank for the help
I like the O.P reflector to!
