Run time of SN2?
Someone mentioned a few days ago that it runs for 2 hours at full brightness and then a couple of hours at reduced brightness after that.
Can't seem to find that post now.
Uh, this is from a while back and wasn't scientific, but mine ran at full brightness for around 30 minutes then started to taper off after that during the next hour. Direct drive, so it will run the batts dry, but it will become more and more dim till it's just barely visible.
1-2 full brightness hours for a space needle II--only if you have it hooked up to a bench supply /ubbthreads/images/graemlins/wink.gif
-Jason
You are most likely right Jason. I have not yet ran the Space Needle for longer than 20 minutes as I tend to use it in 30 seconds bursts. You will be happy to know that your former Space Needle is in a good home. /ubbthreads/images/graemlins/grin.gif
The beam from my newly purchased pre-owned Tigerlight does not look at all impressive next to the Space Needle's beam. I am starting to think I might have a "broken" Tigerlight or something.
