Run-Time Plot - Arc LS 3.6v Lithium
Status
Not open for further replies.
Roy
Farewell our Curmudgeon Administrator
Granbury, Tx USA
This runtime plot is for an Arc LS using one AA sized Tadiran 3.6v Lithium battery. At the end of two hours there was a dull glow still coming from the led.
Equipment used is a photocell and a Radio Shack 22-805 multimeter with a PC interface that is using ScopView software (V 1.08)
The vertical axis is in MA and the horizontal axis is 15 minutes per division.
Be aware that your actual barrety mileage may vary from that indicated by this runtime plot
Roy, I wish you had 3 of my 250mAh 1/3AA Nimhs rite now to do a run time test on....
15min.from that Tadiran...
Come up to Seattle and say that.
Seattle is also the land of $14 CR123A's and nonexistant AAAAs, CR2s and CR-V3s.
If you can get out to the Wall-Mart way off the beaten track, the prices are better. But you're screwed if you live downtown and don't drive.
Moved to reviews. Follow via the link up by your name.
Status
